What is the Fundamental Reason for EMR Diffraction?
In summary, the phenomenon of diffraction can be explained through classical physics and mathematical equations. Photons are not necessary to understand it. The diffracted wave originates at the edge of an obstruction and is affected by factors such as surface waves and boundary conditions. The mathematics accurately predict and explain the behaviors observed in experiments, even if they may go against our intuitive understanding of the physical world.
ChrisXenon
60
I know the textbook definitions and descriptions of the phenomenon, but I'm hoping for a fundamental WHY.
I can see that when a water wave passes an obstacle, the wave spreads out into that object's shadow because the wave's energy is not constrained to any direction and so it will move out in all directions; it is essentially a "pile of water" being pulled down by gravity and it'll be pulled down in all directions so each part of a water wave is like a point source; when part of a wave front, complex interactions occur between all water piles and the emergent result in a wave front. But when the wave front is disrupted by the obstacle the water piles on the end are free to slump in all directions away from the wave front - so the shadow is filled by circular waves propagating from the edge of the wave front. Fair enough. But what is the mechanism which leads to the analogous behaviour with light/photons?
Science news on Phys.org
There is never a good answer to the "Why?" question. Physics never attempts one. All you can hope for is the description of a process that's based on relationships between some basic quantities; i.e. what you can expect to happen under certain conditions. This is not a cop-out answer. Go where you like and you will not get a satisfactory answer to the "Why" question from anyone. This is a hot topic on PF and elsewhere in 'legit' Science discussions. Google "Richard Feynman Why question" and listen to what he has to say. Few people will attempt to contradict that iconic figure'; he has defined the terms.
You want a wave description so you can only get a wave description; photons don't come into it. Photons are seldom the best approach to non-quantum, problems.
You can rely on what the Maths tells you about this sort of thing. Maths is a descriptive language that carries much more 'real information' about a process than any amount of comforting 'physical' verbal descriptions.
If you take the Wave Equation (A second order differential equation in space and time) for an EM wave and you impose boundary conditions - a reflector / a boundary between media with different wave speeds etc. etc. the resulting solution to the equation gives you all the familiar diffraction and refraction phenomena.
For a good metallic reflector, there are currents induced in the surface by the incident wave and those currents set up a new, reflected wave which (when the region of reflection is many wavelengths wide) follows the classical laws of light reflection and also gives the expected diffraction pattern for small objects.
Hmm. I can see why ultimate WHYs are like ultimate TRUTH and can't be obtained. However a "why from the level below" would satisfy me. We routinely use models and analogies to facilitate what we call "understanding" and those help us advance in science & engineering in ways that suit us. Certainly those models and analogies are not ultimately true but they are true enough to be useful. That's what I'm after for diffraction.
Thanks for your help anyway.
As Sophicentaur said ... photons are irrelevant ... there are no issues explaining it with classical physics
Photons are just quantum packets of energy
Reflection, refraction and diffraction are very well understood for a long time using classical physics ... read any decent textbook
You seem to be looking for/expecting something that doesn't exist
Diffraction is a complex issue and Huyghens did not seem to entirely solve it with his secondary wavelets. For instance, if you are in the shadow of an object and you look at the edges of the object they are bright. Further, we do not see an interference pattern within the shadow, arising from the secondary sources.Thomas Young proposed in 1802 that the diffracted wave originates at the edge of the obstruction. It helped to explain the bright edges of an obstacle and why a sphere and a disc produce a bright dot in the centre of the shadow but with different intensity. It also explained why we do not find interference fringes behind an object. Young's idea has been gradually refined up to the present and it is now used a lot in antenna engineering. Whilst no one can say Maxwell's Equations are incorrect, I understand that they did not easily lead to a full explanation of diffraction phenomena. One of the interesting issues is the presence of surface waves (creeping waves) on the obstacle.
Likes ChrisXenon
There's no end to how much the noise performance of a microwave dish can be improved by controlling the currents that flow around and over the edges. The 'hot' Earth where the dish stands can contribute significantly to performance of a high performance radio telescope or link antenna.
I think the good answer to the "why" question is that is what the mathematics say will happen and is matched by experiments. That a lot of physics (and mathematics) are contrary to our intuitive understanding of the physical world. So it becomes easier to "understand" by following the mathematics which says there should be EMR diffraction.
Likes sophiecentaur
+1
Shying away from the Maths is very problematic because there is no 'obvious' tangible / mechanical explanation of diffraction phenomena. All I can say is that, once I bit the bullet and went through some very basic ideas about diffraction (required in A level courses even) the topic began to be 'intuitive' to me. We aren't actually born with any of these Physics Concepts; we need to learn each of them before our brains can intuit them.
Same mechanism?
"Piled up water" needs to be changed to something that corresponds to piled up water in electro-magnetic waves. "Superposed electric fields" seems appropriate to me.
ChrisXenon said:
I can see that when a water wave passes an obstacle, ... But what is the mechanism which leads to the analogous behaviour with light/photons?
If you understand it for waves, why not stick with the EM-wave model of light?
Are photons really more intuitive to you, including their quantum properties like the uncertainty principle? What does the uncertainty principle say about the momentum of a photon that you localize spatially to be exactly at the edge of an obstacle?
Likes sophiecentaur
jartsa said:
Same mechanism?
Jartza - thanks I think you hit the nail on its head. The "piled up water" relies on gravity to provide the reason for it to "slump" in all directions; to be the new point source; I don't know if a super-position of electric fields provides the same answer in EMR land though.
I think the "piled up water" idea is roughly akin to Huyghen's wavelets. Alternatively, the obstruction is a source of re-radiation.
Likes ChrisXenon
FAQ: What is the Fundamental Reason for EMR Diffraction?
What is EMR diffraction?
EMR diffraction is the process by which electromagnetic radiation (EMR) is scattered or bent as it passes through a medium, such as air or water. This phenomenon occurs because EMR is a type of wave that can interact with obstacles or changes in the medium, causing it to change direction.
What causes EMR diffraction?
The fundamental reason for EMR diffraction is the wave nature of EMR. Like all waves, EMR can diffract when it encounters an obstacle or a change in the medium it is traveling through. This diffraction occurs because EMR is made up of oscillating electric and magnetic fields that can interact with the particles in the medium, causing the wave to change direction.
How does EMR diffraction affect the behavior of light?
EMR diffraction can affect the behavior of light in several ways. It can cause light to spread out or become more focused, depending on the size and shape of the obstacle or change in the medium. Diffraction can also cause interference patterns, where waves interact with each other and create areas of increased or decreased intensity.
What are some real-world applications of EMR diffraction?
EMR diffraction has many practical applications, including in optics, telecommunications, and medical imaging. For example, diffraction gratings are used in spectrometers to separate and analyze different wavelengths of light. In telecommunications, diffraction is used to bend radio waves around obstacles to improve signal strength. In medical imaging, X-ray diffraction can be used to create detailed images of internal structures in the body.
Can EMR diffraction be observed in everyday life?
Yes, EMR diffraction can be observed in everyday life. For example, when you see a rainbow, you are witnessing the diffraction of sunlight through water droplets in the air. You can also observe diffraction when looking through a pair of eyeglasses, as the lenses are designed to bend and focus light. Additionally, you can see diffraction patterns when light passes through a narrow opening, such as a slit or a pinhole.
