What is the Galois group and splitting field for the polynomial $x^3-3x+1$?
  • Thread starter Thread starter Chris L T521
The polynomial $x^3-3x+1$ has a root $\theta$, and its splitting field is $\mathbb{Q}(\theta)$. The Galois group of this polynomial is cyclic of order 3. The other roots can be expressed as $a+b\theta+c\theta^2$ for rational numbers $a$, $b$, and $c$. A fused solution to the problem is available, addressing the explicit determination of the other roots. The discussion emphasizes the relationship between the roots and the structure of the Galois group.
Chris L T521
MHB
Here's this week's problem.
Problem: Let $\theta$ be a root of $x^3-3x+1$. Prove that the splitting field of this polynomial is $\mathbb{Q}(\theta)$ and that the Galois group is cyclic of order $3$. In particular the other roots of this polynomial can be written in the form $a+b\theta+c\theta^2$ for some $a,b,c\in\mathbb{Q}$. Determine the other roots explicitly in terms of $\theta$.
This week's question was partially answered correctly by jakncoke (you got the first part, but I don't agree with your root values). You can find our fused solution below.
Proof: $x^3-3x+1$ is irreducible over $\mathbb{Q}$ with the mod 2 test (coefficient mod 2) have no zeros in $\mathbb{Z}_2$.The splitting field for this polynomial would be of the form $Q(\theta,\sqrt{D})$ where D is the discriminant, and $\alpha$ is a root.
Since D is 81, $\sqrt{81} = \pm 9$, so $Q(\theta,\sqrt{81}) = Q(\theta)$. Thus the degree of the Galois group is deg($x^3-3x+1) = 3$ which is cyclic since it is of degree 3 (prime order is cyclic).
Let us now find the other roots in terms of $\theta$. We know that $x^3-3x+1 = (x-\theta)(x^2+\theta x+\theta^2-3)$, so we're interested in finding out whether $x^2+\theta x+\theta^2-3$ has roots in $\mathbb{Q}(\theta)$. By the quadratic formula, the other roots are \[x=\frac{-\theta\pm\sqrt{\theta^2-4(\theta^2-3)}}{2}=\frac{-\theta\pm\sqrt{12-3\theta^2}}{2}.\]
However, for these solutions to be in $\mathbb{Q}(\theta)$, $12-3\theta^2$ must be a square. Since the roots are of the form $a+b\theta+c\theta^2$ for some $a,b,c\in\mathbb{Q}$, we hope to find $a,b,c$ such that
\[12-3\theta^2 = \left(a+b\theta+c\theta^2\right)^2.\qquad\qquad(1)\]
Since $\theta$ is a root of $x^3-3x+1$, this can help us define higher powers of $\theta$ in terms that have degree no more than $2$. With little effort, one finds that $\theta^3=3\theta-1$ and $\theta^4=3\theta^2-\theta$. Thus, after some algebraic manipulations, one finds that (1) can be rewritten as
\[a^2-2bc+(2ab+6bc-c^2)\theta+(2ac+b^2+3c^2)\theta^2=12-3\theta^2.\]
Therefore, we need to solve the system of equations
\[\left\{\begin{aligned}2ac+b^2+3c^2 &= -3\\ 2ab+6bc-c^2 &= 0\\ a^2-2bc &= 12\end{aligned}\right.\]
which (by sheer luck or computer) has the solutions $a=-4$, $b=1$, and $c=2$. Therefore $\left(2\theta^2+\theta-4\right)^2=12-3\theta^2$ and it follows that the other two roots are
\[x=\frac{-\theta+2\theta^2+\theta-4}{2}=\theta^2-2\]
and
\[x=\frac{-\theta-2\theta^2-\theta+4}{2} = 2-\theta-\theta^2.\]
(Note that you can also find the third root once you have the second, since $(\theta^2-2)^2-2=2-\theta-\theta^2$.)$\hspace{1in}\clubsuit$
  • · Replies 0 ·
