What Is the Genetic Code?
In summary, the genetic code refers to the correspondences between nucleotide pair triplets in DNA and amino acids in protein. This means that every triplet in DNA encodes for a specific amino acid in protein. The reason for using nucleotide pair triplets instead of single triplets is because DNA is naturally stored as double-stranded pairs and a single strand is less stable. The term "correspondences" refers to the specific pairing between a triplet and its corresponding amino acid. This process is known as translation and the chart provided shows the different triplet-amino acid correspondences in RNA.
Tyto alba
62
According to https://www.ncbi.nlm.nih.gov/books/NBK21950/ and some other sources:
'Genetic code is the set of correspondences between nucleotide pair triplets in DNA and amino acids in protein.'
What dose correspondences mean in this regard?
I don't understand why nucleotide pair triplets and not simply nucleotide triplets?
P.S. I'm aware of codon and translation.
Biology news on Phys.org
Pairs simply because they are naturally stored as pairs (double-strand). A single strand is sufficient to have all the information, but it is less stable, and you need the pairing mechanism to copy it.
Likes Tyto alba
And what dose correspondences mean in this regard?
Every triplet encodes a single amino acid. The sequence UGU "corresponds" to Cysteine, for example: If the DNA has this triplet, and it is translated, the cell will add Cysteine. UGC also corresponds to Cysteine. Here is a full diagram, to be read from the inside outwards.
Likes Tyto alba
@mfb very good chart, wish I had one like it for teaching years ago.
But. DNA has thymine, not uracil. Uracil is the thymine 'analog' in RNA. So the nice chart is based on the triplets in RNA.
Ah, didn't think of the conversion. The chart is for RNA as the RNA is translated to amino acids. The DNA is translated to RNA before, with T->U.
Related to What Is the Genetic Code?
1. What is the genetic code?
The genetic code is the set of instructions that determines the sequence of amino acids in a protein. It is made up of a specific sequence of nucleotide bases in DNA, which are transcribed into mRNA and translated into amino acids during protein synthesis.
2. How does the genetic code work?
The genetic code works by using a specific sequence of nucleotide bases in DNA to code for specific amino acids. Each three-nucleotide sequence, called a codon, codes for one amino acid. This allows for the synthesis of proteins with different sequences and functions.
3. What are the components of the genetic code?
The components of the genetic code include the four nucleotide bases (adenine, guanine, cytosine, and thymine), which make up DNA, and the 20 amino acids, which are the building blocks of proteins. Additionally, the genetic code also involves enzymes and ribosomes that aid in protein synthesis.
4. How is the genetic code inherited?
The genetic code is inherited from parents through the passing down of DNA. During sexual reproduction, each parent contributes one set of DNA to the offspring, which contains the genetic code. The genetic code can also be altered through mutations, which can occur spontaneously or be caused by environmental factors.
5. Why is the genetic code important?
The genetic code is important because it determines the structure and function of proteins, which are essential for all living organisms. It also allows for genetic diversity and adaptation to changing environments. Understanding the genetic code has also led to advancements in biotechnology and medicine.
  • Biology and Medical
