What is the geometric approach to mathematical research?
The discussion highlights the distinction between geometric and algebraic thinking in mathematical research, referencing notable mathematicians like Maxwell, Dirac, and Gromov, who favor geometric approaches. Geometric thinking involves visualizing mathematical concepts as whole entities rather than through technical or algebraic structures, allowing for a more intuitive understanding of problems. Examples illustrate how complex numbers and linear subspaces can be interpreted geometrically or algebraically, emphasizing that both perspectives represent the same mathematical truths. The conversation acknowledges the challenge of teaching this skill and suggests that developing a geometric mindset may require practice and exposure to various examples. Ultimately, the ability to switch between these approaches is essential for deeper mathematical insight.
kay bei
TL;DR Summary
Maxwell, Dirac and Mikhail Gromov have been known to think Geometrically when doing their theoretical and mathematical research. What does this mean? and How is it different from the Algebraic approach to thinking.
I read this article History of James Clerk Maxwell and it talks about Maxwell and Dirac also at some point. It is said that Maxwell thought geometrically, and also Dirac said he thought of de Sitter Space geometrically. They say their approach to mathematics is geometric. I see this mentioned everywhere. Mikhail Gromov has said he thinks and solves problems geometrically. How is someone supposed to think of Manifolds, and abstract spaces geometrically? I don’t understand this process they use whereby they use geometric thinking to help solve a problem. Are there any basic and more advanced examples which show how someone uses this type of thinking to solve a problem? Please help me understand this. In an interview a mathematician (a fields medalist, I can find the article for you), explained that some mathematicians think algebraically, and others think geometrically and it was said that Gromov thought geometrically. Gromov has said in his interview with AMS that John Nash's thinking style influenced him and that Nash also thinks geometrically, he mentioned also Stephen Smale. I just don’t know the difference in these thinking styles (alebraic vs geometric). How does one develops this without any good examples comparing both approaches side by side on basic and difficult problems. I’ve never had a teacher show the difference. Hopefully someone can clarify this. I am asking because I would prefer to purchase a textbook which takes one approach which suits my thinking style. I may find it easier to think geometrically vs algebraically so it would be beneficial to know what is this difference. There is even a textbook on abstract algebra : a geometric approach. This is so confusing? Is it true that some mathematicians in the field of abstract algebra think in a geometric way to solve their research problems? Do you notice this also among mathematicians? Hopefully someone can help clarify this geometric vs algebraic approach mentioned everywhere.
Mathematics news on Phys.org
This is hard to answer. I think it refers to thinking in entire objects and not so much in technics, coordinates, or algebraic structures.
What are the complex numbers for you? Are they
  • ##r\cdot e^{i\varphi }## or ##a+ib##? analytical
  • a point in the complex plane, or on the Riemann sphere? geometrical
  • a polynomial in ##\mathbb{R}[x]/(x^2+1)##? algebraical
What are linear subspaces for you? Are they
  • linear combinations of a subset of basis vectors? analytical
  • a plane in space or a line in the plane, a hypersurface? geometrical
  • the kernel of a linear transformation? algebraical
See, one can look at mathematical subjects in many different ways, although they all represent the same thing. A geometrical point of view is an imagination of how parts fit into the whole image. It is neither driven by technical descriptions, nor categorial points of view. Instead, mathematical objects become an entity in their own right.
Likes dextercioby
When I think of things I often use geometric means to compose my thoughts. Sometimes you can come up with a drawing that embodies your idea and that guides you to a solution or deeper understanding.
Consider the Flatlands book where 2D visualization is extended to 3D and beyond.
https://en.wikipedia.org/wiki/Flatland
Of course, there are some concepts that can't be thought of geometrically. Great mathematicians will come up with something that helps them work the problem and it will likely be geometric with some kind of mapping to what they are trying to solve.
In vector analysis and other applied fields, it's common to switch back and forth between a geometric view and an algebraic view.
Basically, this is a difficult skill to teach. You will have to extend your abilities to do so.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
