What is the Green's function for this specific problem?
In summary, we can find the Green's function for the given ODE by constructing linearly independent solutions from Legendre polynomials of first and second kind. The Green's function satisfies the ODE, is continuous, and has a unit jump in its derivative at the point of discontinuity. It also satisfies the boundary conditions and is valid for the given problem.
member 428835
Find Green's function of $$K(\phi(s)) = \phi''(s)+\cot(s)\phi'(s)+\left(2-\frac{1}{\sin(s)^2}\right)\phi(s):s\in[0,\alpha]$$
subject to boundary conditions: $$\phi|_{s=0} < \infty\\
\phi|_{s=\alpha} = 0.$$
Green's function ##G## is found via variation of parameters: $$
G_1(s,y) = \frac{v_1(s)v_2(y)}{W(s)}:0<s<y<\alpha\\
G_2(s,y) = \frac{v_1(y)v_2(s)}{W(s)}:0<y<s<\alpha$$
where ##W## is the Wronskian of ##v_1,v_2## and ##v_i## is a linearly independent solution satisfying a boundary condition.
Legendre polynomials of first and second kind (##P_1^1(\cos(s)),Q_1^1(\cos(s))##) solve this ODE, so we construct ##v_1## and ##v_2## from these. To satisfy the finite domain at ##s=0## we take ##v_1 = P_1^1(\cos(s))## and to satisfy ##\phi(\alpha)=0## we take the solution $$v_2(s) = \frac{\tau_2}{\tau_1}(P_1^1(\cos(s))-Q_1^1(\cos(s))):\\
\tau_1 = P_1^1(\cos(\alpha));\,\,\tau_2 = Q_1^1(\cos(\alpha)).$$
Then we find ##W(s) = -2\csc(s)##. Then we know the Green's function from above. However, when I substitute these results into the proposed method, Mathematica is suggesting the ODE is not solved. Any help is much appreciated!
Edit: Evidently the problem is solved when I take solutions of the form $$
G_1(s,y) = \frac{v_1(s)v_2(y)}{W(y)}:0<s<y<\alpha\\
G_2(s,y) = \frac{v_1(y)v_2(s)}{W(y)}:0<y<s<\alpha
since now the boundaries are satisfied ##G1(s=0,y)<\infty;\, G2(s=\alpha,y)=0##. Also, ##G## is continuous: ##G2(s,y)|_{s=y}-G1(s,y)|_{s=y} = 0##, and ##G## exhibits the jump discontinuity at ##s=y##: ##G2'(s,y)|_{s=y}-G1'(s,y)|_{s=y} = 1##.
However, I should note that ##G(s,y)## satisfies the above conditions, but ##G(y,s)## does not. Can anyone comment here?
Your problem isn't self adjoint, so in general ##G(s,y)\neq G(y,s)##. By the way, given that your problem is not self adjoint, are you sure that your formulae,
are correct?
jason
jasonRF said:
Your problem isn't self adjoint, so in general ##G(s,y)\neq G(y,s)##. By the way, given that your problem is not self adjoint, are you sure that your formulae,are correct?
jason
Thanks for replying Jason! Good to know that fact about Green's functions. Regarding the formula, I think it's slightly incorrect. I in fact think if you evaluate the Wronskian at ##y## instead of ##s## you get the correct solution. Then I'm pretty sure the edited solution in post 1 is valid fro this problem.
Taking the proposed ##v##'s from post 1 and their Wronskian, the Green's function suggested in post 1 edit satisfies ##K(G) = 0## for ##s\neq y##, ##G## is continuous, ##G'## has a unit jump at ##s=y##, and boundary conditions are satisfied by ##G1## and ##G2##. What do you think?
Related to What is the Green's function for this specific problem?
1. What is a Green's function?
A Green's function is a mathematical tool used in solving differential equations. It is a function that represents the response of a linear system to an impulse input. It can be used to find the solution to a differential equation with specific boundary conditions.
2. How is Green's function used in physics?
In physics, Green's function is used to solve boundary value problems in classical mechanics, electromagnetism, and quantum mechanics. It is also used in calculating the electric potential and magnetic field of a distribution of charges or currents.
3. What is the difference between a Green's function and a transfer function?
A transfer function is used to describe the relationship between input and output in a linear system, while a Green's function is used to find the solution to a differential equation. Transfer functions are used in control theory, while Green's functions are used in solving boundary value problems.
4. How is a Green's function calculated?
A Green's function is calculated by solving a specific type of differential equation, called the adjoint equation, with a given set of boundary conditions. The solution to this equation is then used to construct the Green's function, which can then be applied to the original differential equation to find the solution.
5. What are the applications of Green's function in engineering?
In engineering, Green's function is used in various fields such as structural analysis, heat transfer, fluid dynamics, and acoustics. It is also used in solving problems related to potential theory, such as finding the stress and displacement in a solid material or the temperature distribution in a conductive medium.
  • Differential Equations
