- #36
kmarinas86
- 979
- 1
DaleSpam said:Which is the general geometric reason that the net energy flux along the ray will never be from cold to hot.
No, this is incorrect. They must be equal in number because they are the same rays, just opposite directions. It is simply not possible to draw a ray that goes from large to small that does not also go from small to large.
I obviously didn't mean 1 ray for 1 ray.
Even though I said, "Are these rays are going to be equal in power?" what I really meant was, "Are light rays, of quantities corresponding to the areas in question, traveling such paths as those two hypothetical light rays, going to match in power?"
DaleSpam said:That assumes that all of the power emitted from the larger goes to the smaller. Tracing a few rays should convince you that is not the case. Some of the rays leaving the larger trace back to the larger.
Of course, one could, if having the time, devise an alternate geometry where 50% of rays of the larger disc hit the smaller one, and where 50% of the rays of the smaller disc hit the larger one.
A simpler geometry would be a two mirror "periscope" like arrangement at 45 angle to each disc, and replacing each disc with a simple rectangular shape object. The percentages could be modified by simply changing the distance from the mirrors until the percentages match.
DaleSpam said:An oscillator occurs whenever you have a second derivative of a quantity which is proportional to the quantity with a negative constant of proportionality. In radiative heat transfer I don't know of any second derivatives of temperature.
It can be found though in the literature:
https://www.google.com/search?q="second+derivative+of+temperature+*+time"
russ_watters said:Regarding shape issues, you should read into the concept of "shape factor" or "view factor": http://web.mit.edu/16.unified/www/SPRING/propulsion/notes/node137.html
Unfortunately, that model assumes that each body has blackbody spectrum. Anything with enough absorption lines or emission lines can deviate signficantly from such a spectrum.
It does indicate however that if two blackbody surfaces are unequal in area but have equal temperature, then the shape factor of each should be reciprocal to their respective area, which does correspond to the point just raised by DaleSpam.
