What is the impact of distance on induction in electrical cables?
  • Thread starter VAIVAW
  • Tags
    Induction
In summary: A twisted pair cable has two conductors twisted around each other. A coaxial cable has one metal conductor surrounded by a plastic jacket. There is no conduit around the 660V line.The 18g cable is a 5 wire + a shield.Moving from 18 to 24 inch separation will probably reduce the coupling by 40%. That's just based on the inverse-square law, where doubling the distance decreases field strength by a factor of four. Other possible solutions: (from simplest to Ouch!) Disconnect the shield at the transmitter end, leave connected at receiver. Use optical couplers at the receiver to keep common mode interference out of the receiver. (Common Mode is when the same interfering signal is on both wires of a differential signal circuit.)
VAIVAW
TL;DR Summary
I have a cable caring 660v 4800 amps below an 18g comm line designed for 24v connections. I am inducting on to the 18g line. How do I calculate voltage increase with the distance from the line?
So if my 18g cable is 18 inches above the 660v line what will my V be one the 18g line? compared to if it is 24 inches per say
Is the 18g cable a twisted pair, or a coaxial cable? Is there a metal conduit around the 660v line?
No conduit around the 660. The 18g is 5 wire + a shield
Please realize that there may be other issues. For instance if the data interface is not differential signalling, a difference in the Ground voltages between Transmitter and Receiver may be part, or all, of the problem. That could occur even with differential signalling if the Ground references have a large difference.
  • Disconnect the shield at the transmitter end, leave connected at receiver.
  • Use optical couplers at the receiver to keep common mode interference out of the receiver. (Common Mode is when the same interfering signal is on both wires of a differential signal circuit.)
  • Use an optically isolated transmitter.
  • Replace the data cable with an optical fiber link.
Or change to a radio link.
{edit}
This one is not very practical, try only if you can not go to optical fiber or radio link. Put a tuned filter in each of the data lines at the receiver, RLC filter tuned to the interfering frequency. If the power line is 3-phase you may also need filtering at the third harmonic, three times the line frequency.
{edit}
Cheers,
Tom
The shielding on the comms cable seems to afford zero protection against the magnetic coupling and the conductors sound not to be balanced, so no protection from that either. Also be careful about ground loops (as mentioned).
FAQ: What is the impact of distance on induction in electrical cables?
What is induction in electrical cables?
Induction in electrical cables is the process by which an electric current is produced in a conductor when it is exposed to a changing magnetic field. This can occur when the cable is placed near a source of alternating current or when the current in the cable itself is constantly changing.
How does distance affect induction in electrical cables?
The impact of distance on induction in electrical cables is significant. The strength of the induced current decreases as the distance between the cable and the source of the changing magnetic field increases. This is because the magnetic field becomes weaker as it spreads out over a larger area.
What factors besides distance can affect induction in electrical cables?
Aside from distance, the strength of the magnetic field, the frequency of the alternating current, and the material of the cable can also impact induction. A stronger magnetic field or higher frequency can result in a stronger induced current, while a different material may have a different level of conductivity and affect the induction process.
How can the impact of distance on induction in electrical cables be minimized?
The impact of distance on induction in electrical cables can be minimized by using materials with high conductivity, increasing the frequency of the alternating current, and minimizing the distance between the cable and the source of the changing magnetic field. Shielding the cable can also help reduce the effects of induction.
What are some practical applications of understanding the impact of distance on induction in electrical cables?
Understanding the impact of distance on induction in electrical cables is crucial in designing and maintaining efficient electrical systems. It can also be applied in the development of electromagnetic devices, such as transformers and motors. In addition, this knowledge can help prevent interference between different electrical systems in close proximity.
