What is the Impact Velocity of a Mouse Dropped by an Owl?
In summary, the problem involves an owl dropping a mouse from a height of 10m while flying at a horizontal speed of 5 m/s. The task is to find the mouse's impact velocity, given as a magnitude and angle. To solve this, the quadratic formula is used to find the time it takes for the mouse to reach the ground. The angle can be determined by finding the components of the final velocity in the horizontal and vertical directions and using them to solve for the angle. The final velocity can be found by using the known values of initial velocity, displacement, acceleration, and time in the equations for horizontal and vertical motion.
Istinkatmath
An owl accidentally drops a mouse it was carrying while flying horizontally at a speed of 5 m/s. The mouse drops to the ground 10m below. What is the mouse's impact velocity? Give the answer as a magnitude and clearly defined angle.
As of right now I'm not even sure how to approach this problem, if I had an angle to work with I think I could get through it but at the moment I'm bamboozled.
Thanks for any help :D
All i know is that you have to use quadratic formula on -4.9t^2+5t+10 to get the time it took to get to the ground. then divide 10m by t to get the speed at impact. no idea how to get the angle. on second thought i think the angle is the slope of the tangent of the parabola at where it hits the x-axis on the right side but not sure.
this is 2 dimensional though, wouldn't using the quadratic formula like that indicate that the mouse was shot straight up in the air and then is falling back down? I think I have to split it into X and Y components, but I'm not sure how to do so.
Edit: Duh, vertical motion is independent of horizontal motion, so yea you're right. Still unsure how to get the angle out of this though.
Hi Istinkatmath,
The impact velocity is the final velocity (right before it hits ground). How can you find the components of the final velocity? Do you see what to do with them?
i think that's my problem at the moment, i don't see what to do with the components.
Edit: thanks for helping and caring enough to respondI solved the quadratic equation and got my final velocity to be 4.933 m/s, now I just have to figure out what to do with it : /
I don't see how you got that result. Can you show the work you did to get it?
Remember that the horizontal and vertical components are handled separately. So think about what you know for the horizontal motion (initial horizontal velocity, final horizontal velocity, horizontal displacement, horizontal acceleration and time). You're looking for the x-component of the final velocity, so how could you find it?
Separately, think about the vertical motion and what you know about it in this problem (initial vertical velocity, final vertical velocity, vertical displacement, vertical acceleration and time). With these, you're looking for the y-component of the final velocity.
yea i was wrong. so when i am setting up the y(t) function for motion, would it be the following? y= 10 + Voy(t)-1/2gt^2 ? All of the examples in my book give an angle to work with from the beginning, and I don't understand how I can find t without it.
That's right; the general equation is:
[tex]
y=y_0 + v_{0y} t +\frac{1}{2}a_yt^2
[/tex]
You've already plugged in [itex]y_0=10[/itex] and [itex]a_y=-g[/itex]. You also know (from the problem) what [itex]y[/itex] and [itex]v_{oy}[/itex].
The value [itex]y[/itex] is the coordinate of the mouse when it hits the ground; if it starts at 10m, what is it at after it falls 10m?
The value [itex]v_{0y}[/itex] is how much of the initial velocity that is in the vertical direction. What would that be?
Once you plug those in, your only unknown should be time and you can find it.
FAQ: What is the Impact Velocity of a Mouse Dropped by an Owl?
How do I approach solving a 2d kinematics problem?
To solve a 2d kinematics problem, you need to break it down into smaller parts and analyze each part separately. First, draw a diagram and label all known and unknown variables. Then, use equations of motion to solve for the unknown variables in each direction separately.
What are the key principles of 2d kinematics?
The key principles of 2d kinematics include the independence of motion in different directions, the use of vector components to break down motion, and the use of equations of motion to solve for unknown variables.
Can you provide an example of a 2d kinematics problem?
Yes, an example of a 2d kinematics problem would be a ball being thrown off a cliff with an initial velocity of 20 m/s at an angle of 30 degrees above the horizontal. The ball's position, velocity, and acceleration can be calculated at different time intervals using the principles of 2d kinematics.
How do I know which equations to use when solving a 2d kinematics problem?
The equations of motion used in 2d kinematics are the same as those used in 1d kinematics, with the addition of vector components. The key is to identify the variables you have and the ones you need to solve for, and then choose the appropriate equation that relates those variables.
What are some common mistakes to avoid when solving a 2d kinematics problem?
Some common mistakes to avoid when solving a 2d kinematics problem include mixing up vector components, not using the appropriate units, not considering the direction of motion, and not breaking down the problem into smaller parts. It's also important to double check your calculations and units to ensure accuracy.
