What is the Improved Solution for a Non-Small Angle Simple Pendulum?
  • MHB
  • Thread starter Ackbach
  • Tags
    2015
In summary, a non-small angle simple pendulum is a weight suspended from a fixed point by a string or rod that demonstrates simple harmonic motion. The improved solution for this type of pendulum is a more accurate mathematical formula that considers the effects of small angles on its period. It is important to use this improved solution for more accurate calculations and understanding of pendulum behavior in real-world situations. Factors such as length, mass, and gravity affect the period of a non-small angle simple pendulum, and the improved solution can be applied in various real-life scenarios, such as designing clock pendulums and analyzing pendulum motion in engineering and physics experiments.
Ackbach
MHB
4,155
93
Here is this week's POTW:
In freshman calculus-based physics, you studied the simple pendulum, and possibly the physical pendulum. Typically, in such problems, you used the small-angle approximation to simplify the resulting differential equation for $\theta$, the angle the pendulum makes with the vertical. Let us improve on this solution by not allowing the small-angle approximation. For the simple pendulum, reduce to a single integral the differential equation for $\theta$. You may obtain an implicit result, and you may neglect air resistance and any other second-order effects such as the Coriolis effect. Assume the length of the pendulum is $\ell$, $\theta(0)=\theta_0$, and $\dot{\theta}(0)=0$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to topsquark for his correct solution! Actually, he solved the physical pendulum, not the simple pendulum, but that's ok. Here is his solution:
This problem seems to me to be intractable if we do it the straightforward way. But hey, I'm a Physicist and have a trick up my sleeve.
Let's work this out using the work-energy theorem. I'm using the physical pendulum for the equations but the diagram below is for the simple pendulum.
\(\displaystyle W_{nc} = \Delta KE + \Delta PE\)
There are no non-conservative forces present, so \(\displaystyle W_{nc} = 0\)
\(\displaystyle 0 = \Delta KE + \Delta PE\)
The KE is easy:
\(\displaystyle \Delta KE = \left ( \frac{1}{2} \right ) I \dot {\theta} ^2 - \left ( \frac{1}{2} \right ) I \dot {\theta _0} ^2\)
Define the zero of the potential energy to be at the bottom of the swing of the pendulum and the height of the pendulum at \(\displaystyle \theta _0\) to be h. Using the diagram below, we have that
\(\displaystyle cos(\theta) = \frac{L - h}{L} \implies h = L(1 - cos(\theta))\).
*Note that for the physical pendulum L is actually the radial distance from the pivot to the center of mass.
So the PE becomes:
\(\displaystyle \Delta PE = mgL(1 - cos(\theta)) - mgL(1 - cos( \theta _0)) \)
So back to the energy equation:
\(\displaystyle 0 = \left [ \left ( \frac{1}{2} \right ) I \dot {\theta} ^2 - \left ( \frac{1}{2} \right ) I \dot {\theta _0} ^2 \right ] + \left [ mgL(1 - cos(\theta)) - mgL(1 - cos( \theta _0)) \right ] \)
Noting that \(\displaystyle \dot{ \theta _0} = 0\) we get:
\(\displaystyle 0 = \left ( \frac{1}{2} \right ) I \dot {\theta} ^2 + mgL(cos(\theta _0) - cos(\theta))\)
or
\(\displaystyle 0 = \dot{\theta}^2 + \frac{2mgL}{I} (cos(\theta_0) - cos(\theta))\)
\(\displaystyle \dot{\theta} = \sqrt{\frac{I}{2mgL} (cos(\theta) - cos(\theta_0))}\)
Just for comparison, for a simple pendulum, \(\displaystyle I = mL^2\), where L is now the length of the string on the pendulum, giving:
\(\displaystyle \dot{\theta} = \sqrt{\frac{L}{2g} (cos(\theta) - cos(\theta_0))}\)
Back to the physical pendulum. This equation is separable:
\(\displaystyle \dot{\theta} = \frac{d \theta}{dt} = \sqrt{\frac{2gmL}{I} (cos(\theta) - cos(\theta_0))}\)
\(\displaystyle dt = \sqrt{\frac{I}{2mgL}}\left [ cos(\theta) - cos(\theta_0)) \right ] ^{-1/2} ~d \theta \)
\(\displaystyle \int_{t_0}^t dt = \int _{\theta _0}^{\theta} \sqrt{\frac{I}{2mgL}}\left [ cos(\theta) - cos(\theta_0)) \right ] ^{-1/2} ~d \theta \)
\(\displaystyle t - t_0 = \int _{\theta _0}^{\theta} \sqrt{\frac{I}{2mgL}}\left [ cos(\theta) - cos(\theta_0)) \right ] ^{-1/2} ~d \theta \)
Since \(\displaystyle t_0 = 0\) we have, finally:
\(\displaystyle t = \sqrt{\frac{I}{2mgL}} \int _{\theta _0}^{\theta} \left [ cos(\theta) - cos(\theta_0)) \right ] ^{-1/2} ~d \theta \)
This integral has no closed form, but note that if \(\displaystyle \theta = 0\) we can put the integral in terms of an incomplete elliptic integral of the first kind.
FAQ: What is the Improved Solution for a Non-Small Angle Simple Pendulum?
What is a non-small angle simple pendulum?
A non-small angle simple pendulum is a physical system that consists of a weight suspended from a fixed point by a string or rod. It is used to demonstrate the principles of simple harmonic motion and can be found in many physics classrooms.
What is the improved solution for a non-small angle simple pendulum?
The improved solution for a non-small angle simple pendulum is a mathematical formula that takes into account the effects of small angles on the period of the pendulum. It is more accurate than the traditional formula, which assumes that the angle of the pendulum is small.
Why is it important to use the improved solution for a non-small angle simple pendulum?
Using the improved solution allows for more accurate calculations of the period of a non-small angle simple pendulum. This is important for understanding and predicting the behavior of pendulums in real-world situations.
What factors affect the period of a non-small angle simple pendulum?
The period of a non-small angle simple pendulum is affected by the length of the string or rod, the mass of the weight, and the acceleration due to gravity. Other factors, such as air resistance and friction, may also have an impact.
How can the improved solution for a non-small angle simple pendulum be applied in real life?
The improved solution for a non-small angle simple pendulum can be applied in many real-life situations, such as designing and calibrating clock pendulums, determining the length of a pendulum needed for a desired period, and analyzing the motion of pendulums in engineering and physics experiments.
