What is the integral of $\frac{x^2-1}{\sqrt{2x-1}}$?
  • MHB
  • Thread starter karush
In summary, we used the substitution $u=2x-1$ to transform the given integral into an easier form. Then, we simplified the integrand and applied the power rule to find the final result of $I=\dfrac{\frac{\left(2x-1\right)^\frac{5}{2}}{5}+\frac{2\left(2x-1\right)^\frac{3}{2}}{3}+\sqrt{2x-1}}{4}-\sqrt{2x-1}$.
karush
MHB
3,269
$\tiny{307.4.5.71}$
\begin{align}
\displaystyle
I_{71}&=\int{\frac{x^2-1}{\sqrt{2x-1}}}dx\\
u&=2x-1\therefore dx=\frac{1}{2}du\\
x&=\frac{u+1}{2}\\
I_u&= \int{\frac{{[(1/2)(u+1)]}^2-1}{\sqrt{u}}}
\cdot \frac{1}{2} \, du\\
\end{align}
$\textit{not sure what is best to do next?}$
Your substitution is a good one...let's write the integral as:
\(\displaystyle I=\frac{1}{2}\int\frac{\left(\frac{u+1}{2}\right)^2-1}{u^{\frac{1}{2}}}\,du\)
Next, let's multiply by \(\displaystyle 1=\frac{4}{4}\):
\(\displaystyle I=\frac{1}{8}\int\frac{(u+1)^2-4}{u^{\frac{1}{2}}}\,du\)
Can you proceed?
$\tiny{307.4.5.71}$
\begin{align}
\displaystyle
x&=\frac{u+1}{2}\\
&=\frac{1}{8}\int\frac{(u+1)^2-4}{u^{\frac{1}{2}}}\,du
=\frac{1}{8}\int\frac{u^2+2u-3}{u^{1/2}}
\end{align}
$\text{this or go with $v=u+1$ for a trig id}$
Just simplify the integrand...you will have 3 terms containing u to various powers, to which you can then apply the power rule. (Yes)
$$\int\frac{x^2-1}{\sqrt{2x-1}}\,\text{d}x$$
$$u=\sqrt{2x-1}\quad x=\frac{u^2+1}{2}$$
$$\text{d}u=\frac{1}{\sqrt{2x-1}}\text{ d}x$$
$$\int\left(\frac{u^2+1}{2}\right)^2-1\text{ d}u$$
$\tiny{307.4.5.71}$
\begin{align}
\displaystyle
x&=\frac{u+1}{2}\\
=\frac{1}{8}\int\frac{u^2+2u-3}{u^{1/2}}\, du\\
&=\frac{1}{8}\left[\int\frac{u^2}{u^{1/2}} \, du
+2\int\frac{u}{u^{1/2}}\, du
-3\int\frac{1}{u^{1/2}}\, du\right] \\
&=\frac{1}{8}\left[\dfrac{2u^\frac{5}{2}}{5}
+\dfrac{4u^\frac{3}{2}}{3}
-6\sqrt{u}\right]\\
I&=\dfrac{\frac{\left(2x-1\right)^\frac{5}{2}}{5}+\frac{2\left(2x-1\right)^\frac{3}{2}}{3}+\sqrt{2x-1}}{4}-\sqrt{2x-1}
\end{align}
FAQ: What is the integral of $\frac{x^2-1}{\sqrt{2x-1}}$?
What does "307.4.5.71 int u subst9" refer to?
"307.4.5.71 int u subst9" is a numerical code that likely refers to a specific substance or material being studied in a scientific experiment or research project. It could also be a reference number for a particular experiment or set of data.
What is the significance of the numbers in "307.4.5.71 int u subst9"?
The numbers in "307.4.5.71 int u subst9" likely have a specific meaning within the context of a scientific study or project. They could represent the composition, concentration, or other characteristics of the substance being studied.
What type of research or experiment involves "307.4.5.71 int u subst9"?
Without additional context, it is difficult to determine the exact type of research or experiment that involves "307.4.5.71 int u subst9." It could be related to any scientific field such as chemistry, biology, or physics.
Is "307.4.5.71 int u subst9" a commonly studied substance?
It is not possible to determine if "307.4.5.71 int u subst9" is a commonly studied substance without more information. It could be a newly discovered substance or one that is only relevant to a specific study or project.
Can you explain the meaning of "int u subst9" in "307.4.5.71 int u subst9"?
The meaning of "int u subst9" is not clear without more context. It could be an abbreviation for a specific term or description of the substance, or it could be a code for a particular stage or aspect of the research or experiment.
