What is the Integral of Square Root of T over T+1 with Substitution?
In summary, the conversation discussed performing a substitution with a definite integral, which requires changing the bounds and rewriting the integrand, differential, and limits in terms of the new variable. The result for the given problem was found to be 1.7857 after using the substitution $U=\sqrt{t}$ and applying the formula $2\left[U-\tan^{-1}(U)\right]_0^4.$
karush
MHB
3,269
$\displaystyle
\int_0^4 {\frac{\sqrt{t}}{t+1}}dt
$\displaystyle
U=\sqrt{t}\ \ \ t=U^2 \ \ \ dt=2Udu
$\displaystyle
\frac{\sqrt{t}}{t+1} \Rightarrow \frac{U}{U^2+1}
$\displaystyle
\int_0^4 \frac{U}{U^2+1} 2Udu
if ok so far tried $U= sec^2(\theta)$
but couldn't not get answer which is
MSP16261d915dhdb3321026000060d03dc1b0d27g11
When you perform a substitution with a definite integral, you need to change the bounds. So for $0\le t\le4$ you get $0\le u\le 2$ since $u=\sqrt t.$ Now, note that $\dfrac{{{u}^{2}}}{{{u}^{2}}+1}=\dfrac{{{u}^{2}}+1-1}{{{u}^{2}}+1}=1-\dfrac{1}{{{u}^{2}}+1},$ so if you integrate the right side, you'll see immediate integrals there.
So this will go to
$2\left[U-\tan^{-1}(U)\right]_0^4$
$2\left[√t-\tan^{-1}√t\right]_0^4=1.7857$
You have the correct result, but you could have just used:
\(\displaystyle 2\left[u-\tan^{-1}(u) \right]_0^2=2\left(2-\tan^{-1}(2) \right)\approx1.78570256441182\)
Once you make a substitution in a definite integral and have rewritten the integrand, differential and limits in terms of the new variable, there is no need to consider the old variable again. :D
I that about that...
Still need more practice I get stuck easy with these...
Mahalo
FAQ: What is the Integral of Square Root of T over T+1 with Substitution?
What is the concept of "integral with substitution"?
Integral with substitution, also known as u-substitution, is a method used to simplify integrals by substituting a variable in the integral with another variable. This is done in order to make the integral easier to solve.
When should I use "integral with substitution"?
"Integral with substitution" should be used when the integral contains a complicated expression or when the variable in the integral is not easily integrable. Substituting a variable can make the integral easier to solve and provide a more simplified solution.
How do I perform "integral with substitution"?
To perform "integral with substitution," you must first identify a suitable substitution variable. This variable should be chosen in a way that simplifies the integral. Then, use the chain rule to express the original integral in terms of the new variable. Finally, solve the new integral and substitute the original variable back in to get the final solution.
What are the benefits of using "integral with substitution"?
Using "integral with substitution" can make solving integrals easier and more efficient. It also allows for a wider range of integrals to be solved, as some integrals may not be easily solvable without using substitution. Additionally, it can provide a more simplified solution to the integral.
Are there any limitations to using "integral with substitution"?
While "integral with substitution" can be a useful method, it may not be applicable to all integrals. Additionally, finding a suitable substitution variable may not always be straightforward, and it may require trial and error. It is important to carefully consider if "integral with substitution" is the best method to solve a specific integral before using it.
