What is the Integration by Parts method used for?
  • MHB
  • Thread starter karush
In summary, we learned about integration by parts and how to apply it to solve integrals. In this specific example, we used the LIATE rule to determine our substitution for $u$ and $dv$, and then integrated by parts twice to simplify the integral to a form that we can easily solve. The final solution is $\frac{{t}^{2}\left(\ln\left({t}\right)\right)^2 }{2}-\frac{{t}^{2}\left(\ln\left({t}\right)\right) }{2}+\frac{{t}^{2}}{4}+ C$.
karush
MHB
3,269
$\tiny\text{Whitman 8.7.26 Integration by Parts} $ nmh{818}
$\displaystyle
I=\int t
\left(\ln\left({t}\right) \right)^2
\ d{t}
=\frac{{t}^{2}\left(\ln\left({t}\right)\right)^2 }{2}
+\frac{{t}^{2}}{4}
+ C$
$\displaystyle uv-\int v \ d{u} $
$\begin{align}\displaystyle
u& = t &
dv&=\left(\ln\left({t}\right) \right)^2 \ d{t} \\
du&= dt&
v& =t\left(\ln\left({t}\right)^2 - 2\ln\left({t}\right)+2\right)
\end{align}$
$\text{$v$ reintroduced $t$
so not sure of $u$ $dv$ substitutions } $
According to LIATE, you should first try:
\(\displaystyle u=\ln^2(t)\,\therefore\, du=2\ln(t)\frac{1}{t}\,dt\)
\(\displaystyle dv=t\,dt\,\therefore\,v=\frac{t^2}{2}\)
$\displaystyle
I=\int t
\ d{t}
+\frac{{t}^{2}}{4}
+ C$
u& = \ln^2 \left({t}\right) &
dv&= t \ dt \\
du&=\frac{2\ln\left({t}\right)}{t} \ dt&
v& =\frac{t^2}{2}
\end{align}$
So
$\displaystyle
\frac{{t}^{2}\ln^2 \left({t}\right)}{2}
-\int\frac{t^2}{2} \frac{2\ln\left({t}\right)}{t} \ dt
\implies\frac{{t}^{2}\ln^2 \left({t}\right)}{2}
-\int t \ln\left({t}\right) \ dt $
For
$\displaystyle
u& = \ln\left({t}\right) &
dv&= t \ dt \\
du&=\frac{1}{t} \ dt&
v& =\frac{t^2}{2}
\end{align}$
$\displaystyle\frac{{t}^{2}\ln\left({t}\right)}{2}
-\int\frac{t}{2} \ dt =\frac{{t}^{2}\ln\left({t}\right)}{2}- \frac{{t}^{2}}{4}$
and finally...
$\displaystyle
+\frac{{t}^{2}}{4}
+ C$
FAQ: What is the Integration by Parts method used for?
1. What does "-w8.7.26 IBP int (ln t)^2 dt" represent?
The notation "-w8.7.26 IBP int (ln t)^2 dt" is a mathematical expression that represents the indefinite integral of the natural logarithm squared of t, using the technique of integration by parts. It is commonly used in calculus and physics to solve problems involving change and accumulation.
2. How do you solve "-w8.7.26 IBP int (ln t)^2 dt"?
To solve this expression, you would first apply the integration by parts technique, which involves choosing two parts of the integrand and using a specific formula to integrate them together. In this case, you would choose the natural logarithm squared as one part, and the differential of t as the other part. The resulting integral can then be solved using substitution or other techniques.
3. What are the practical applications of "-w8.7.26 IBP int (ln t)^2 dt"?
The indefinite integral of the natural logarithm squared of t has many practical applications in fields such as physics, engineering, and economics. It can be used to model exponential growth and decay, calculate the area under a curve, and solve problems involving rates of change and optimization.
4. Is there a specific method for solving "-w8.7.26 IBP int (ln t)^2 dt" or can it be solved using different techniques?
There are several different techniques that can be used to solve this integral, depending on the complexity of the function and the specific problem being solved. Integration by parts is one common method, but other techniques such as substitution, partial fractions, and trigonometric identities may also be used.
5. How can I use "-w8.7.26 IBP int (ln t)^2 dt" to solve real-world problems?
The indefinite integral of the natural logarithm squared of t can be used to solve a variety of real-world problems, such as calculating compound interest, modeling population growth, and finding the velocity of a falling object. By understanding how to solve this type of integral, you can apply it to a wide range of practical situations and make more accurate predictions and analyses.
