What is the interpretation of the vacuum correlation function in QFT
In summary, the conversation discusses the interpretation and understanding of the Klein-Gordon field in quantum field theory. The propagator G(x-y) is defined as the correlation function <0|phi(y)phi(x)|0>, which is commonly interpreted as the creation and destruction of a virtual particle at x and y respectively. However, this interpretation does not make sense intuitively because the vacuum is Lorentz invariant and there should be another virtual particle created at an earlier time and destroyed at x. The conversation also delves into the path integral formalism and its connection to the canonical formalism. Additionally, questions are raised about the measurement of the field operator phi(x) and its eigenstates. In summary, the discussion highlights the complexities and challenges
Sonderval
234
I'm currently trying to make some intuitive sense out of Quantum field theory, but I'm not really understanding the vacuum.
Consider a real (or complex, with + in the right places) scalar
particle (a Klein-Gordon field).
Now consider the propagator (or correlation function)
G(x-y)= <0|phi(y) phi(x) |0>
(where I assume that the two operators are correctly time-ordered already)
My questions are related to how exactly to interpret this.
A standard interpretation seems to be to say that since phi(x) is (or
contains) a creation operator for a virtual particle, this describes
the creation of a virtual particle at x and its destruction at y.
My first problem is that intuitively this does not make much sense,
because the vacuum is completely Lorentz invariant, so for each particle
created at x (and later destroyed at y), there would be another
virtual particle that was created at an earlier time and is destroyed
at x. After all, the vacuum is absolutely stationary.
So here is my Question 1: In what sense is this interpretation to
be understood?
I could try to understand it in a sense from a path integral
interpretation. I look at the vacuum-to-vacuum amplitude <0|0>. There
I have to integrate over all field configurations that have different
contributions according to their action. For each configuration, I
could calculate phi(y)phi(x), and summing over all configurations with
the appropriate weights, I could see the correlation. This would give
meaning to the term "vacuum fluctuation" if applied to each
configuration separately - if the field value is very large at x and
if y is a near-by point, the field will with higher probability be
large there as well because otherwise the action would be very
large. I think this is how correlation functions are used in lattice
gauge theory.
So Question 2 is simply: Is this interpretation within the path
integral formalism correct? If so, is there a way to transfer it to
the canonical formalism?
Furthermore, on the other hand, standard lore is that for any operator Q
<0|Q|0>
is the vacuum expectation value of Q, i.e., it is the value I would
get if I were to perform a very large number of measurements of the
variable Q.
So if I now set Q=phi(y)phi(x), this would tell me that G(x-y) is the
expectation value I would get if I measure first phi(x), then phi(y)
and then calculate the product of both.
So let's create infinitely many copies of the vacuum (so I can perform
enough measurements to get an expectation value). In each of my
copies, I now perform a measurement of the field at x. This will
create a new state of my universe. In quantum mechanics, I would say
that this new state would be an eigenstate to phi(x) (which would then
evolve), but - here is my Question 3 - does phi(x) actually *have*
eigenstates? (If so, what are they, especially if phi is a complex
field?) And is there actually any way I could perform this
measurement of phi? How do you measure a field value of a quantum
field anyway? (Again, especially in the case of a complex field?)
Since I'm now in a new state phi(x)|0>, I could interpret
as the matrix element of getting from my new state back to the vacuum
state by applying another field measurement phi(y). This would then
mean that <0|phi(y) phi(x) |0> is something like the probability of
getting from vacuum back to a vacuum if I apply two subsequent
measurements of phi (similar to Fermi's golden rule, where a matrix
element also gives a transition probability). So finally, my question
4: Would this be a correct interpretation of <0|phi(y) phi(x) |0>?
This is my first post here - I've read a lot hereabouts, but did not really find an answer to these question. Thanks for any help.
The vacuum is Lorentz invariant, but the state phi(x)|0> is not Lorentz invariant; the Lorentz-invariant vacuum has been hit with an operator that is explicitly associated with a specific spacetime point. To be clear, the operator phi(x) hits a state with no particles, |0>, and turns it into a state with one particle (if we're talking about a free theory here). The state |0> contains no particles for phi(x) to destroy.
Lorentz invariance tells you thinks like
[itex]\left<0|\phi(y)\phi(x)|0\right> = \left<0|\phi(y-x)\phi(0)|0\right>[/itex]
i.e., the amplitude to propagate from x to y is the same as the amplitude to propagate from the spacetime origin to y-x, and perhaps this is what your intuition corresponds to?
Yes, your description sounds good. Are you asking for the steps used to derive the path integral from the operator formalism, and vice versa? Or are you looking for something else?
There are some issues here. For instance, phi(y)phi(x) is not in general Hermitian even if we are talking about a real scalar field (which is why its vacuum expectation value, G(x-y), is in general complex and not real). So phi(y)phi(x) apparently not a good observable.
I personally don't have particularly good answers for your questions about measuring the field operator, but I think again you should not expect it to be meaningful to talk about measuring a operator that is not Hermitian. Mathematically, at least, if phi is real then phi(x), being Hermitian, should indeed have a complete set of eigenstates, but I'm not aware that these eigenstates have any particularly straightforward physical interpretation.
However, if we decide that there is indeed some physical operation that corresponds to "measuring" phi(x), note that doing this measurement puts the system in an eigenstate of phi(x), not the state phi(x)|0>, which is not an eigenstate of phi(x). I don't think that <0|phi(x)phi(y)|0> should be interpreted as a series of two measurements of phi(x) at different spacetime points.
Hi TheDuck,
thanks for the answer.
Sigh of relief. I still have trouble to transfer this intuitive picture to the canonical picture - there, I should have states that are superpositions of field configurations resulting in the same things as in the path integral picture (similar to psi(x) being a superposition of the particle position states in normal QM), but I have no clue how to write this down mathematically.
I'm also still confused by the meaning of phi(x).
If phi(x) does not correspond to any physical observable, then what is meant by calling <0|phi(y)phi(x)|0> a "correlation function"? What is the thing that is correlated?
I'm especially puzzled when I think of a quantum field theory of, for example, an elastic membrane or a mattress (an example used in the book by Stone, "Physics of Quantum fields").
Here, the classical field phi(x) is directly the displacement of the medium which is surely a good and valid observable. How can quantising this kind of theory lead to an operator phi that does not correspond directly to this observable?
So at least in this kind of theory (which is a real scalar theory), phi(x) should have a clear physical interpretation, shouldn't it?
Ah, yes, of course in this case phi corresponds to exactly the physical observable it represents classically. I guess I was thinking about the case of the fields used to describe fundamental particles, where I don't know what it would mean exactly to measure the field operator.
O.k., thanks for that clarification.
Neither do I know, that's probably part of my problem with the VEV.
If the particle were a real scalar Klein-Gordon-particle, like a neutral pion, would phi classically be a kind of particle density?
FAQ: What is the interpretation of the vacuum correlation function in QFT
What is a vacuum correlation function in quantum field theory (QFT)?
A vacuum correlation function in QFT is a mathematical quantity that describes the relationship between two or more fields in a quantum vacuum state. It is a measure of the probability that a certain configuration of fields will occur in the vacuum state.
How is a vacuum correlation function calculated in QFT?
In QFT, a vacuum correlation function is calculated using the principles of quantum mechanics and field theory. This involves taking the expectation value of the product of two or more fields in the vacuum state. The resulting quantity is then used to make predictions about the behavior of particles and interactions in the vacuum state.
What does the vacuum correlation function tell us about the vacuum state?
The vacuum correlation function provides information about the properties of the vacuum state, such as its energy, momentum, and particle interactions. It also helps us understand the underlying structure of the vacuum and how particles interact with it.
How is the vacuum correlation function used in practical applications?
The vacuum correlation function is used in a variety of practical applications, such as calculating scattering amplitudes, predicting particle interactions, and understanding the behavior of quantum fields in different environments. It is also a crucial component in developing and testing theoretical models in QFT.
Can the vacuum correlation function be measured experimentally?
While the vacuum correlation function is a theoretical concept, it can indirectly be measured experimentally through the use of particle detectors and other high-energy experiments. However, the exact values of the vacuum correlation function are often difficult to measure precisely due to the complex nature of quantum field interactions.
