What is the ionized and unionized form?
  • Thread starter MitsuShai
  • Tags
    Form
In summary, the Henderson Hasselbach equation deals with the relationship between the uncharged and charged forms of a molecule, which can also be referred to as the conjugate base and acid. However, there may be confusion between the terms "uncharged" and "unionized" as they refer to different states of the molecule. Additionally, ions can be either positively or negatively charged, depending on the number of electrons and protons, and zwitterions, such as amino acids, can have both a positive and negative charge at different pH levels.
MitsuShai
159
So I'm doing a henderson hasselbach type problem.
I learned in biochemistry that the uncharged form is the conjugate base [A-] and the charged form is the acid [HA]. However, I looked up on google about the henderson hasselbach equation and found that the unionized form is [HA], while the ionized form is [A-]. I got it from this: http://www2.umt.edu/medchem/teaching/Lecture1-Pharmaceutics.pdf
Does uncharged and unionized mean the same thing? I thought it did, but now I'm a bit confused.
Chemistry news on Phys.org
Ions are atoms/molecules where the total number of electrons does not equal the total number of protons. If you have more electrons than protons, one has an anion - a negatively charged ion. If you have more protons than electrons, one has a cation - a positively charged ion. And then you can also have zwitterions.
Remember, amino acids can be zwitterions. They have both a carboxylic acid functional group and an amine functional group. The protonation state for the two groups will vary as a function of pH. This, it seems, is the source of the confusion, based on what you've written.
FAQ: What is the ionized and unionized form?
What is the ionized form?
The ionized form refers to a molecule or compound that has gained or lost one or more electrons, resulting in a positive or negative charge. This process is known as ionization.
What is the unionized form?
The unionized form refers to a molecule or compound that has an equal number of protons and electrons, resulting in a neutral charge. This form is also known as the non-ionized form.
How does ionization occur?
Ionization can occur through various processes such as chemical reactions, exposure to high energy radiation, or electrical discharge. It involves the transfer of electrons from one atom or molecule to another.
What are the implications of ionization?
Ionization can greatly affect the properties and behavior of a molecule or compound. For example, ionization can change the solubility, reactivity, and stability of a substance. In biological systems, ionization can also affect the function of proteins and enzymes.
Can ionized and unionized forms coexist?
Yes, ionized and unionized forms can coexist in a solution or substance. The ratio of ionized to unionized forms is determined by the pH of the solution and the chemical properties of the substance. This can greatly impact the overall properties of the substance.
