What is the kinetic energy when an object reaches escape velocity?
In summary, escape velocity is the velocity required for an object to escape the gravitational pull of a body, and it decreases as altitude increases. At escape velocity, the object's kinetic energy is equal to its gravitational potential energy, resulting in a net energy of zero. This means that the object will continue to move at the same speed without any external forces acting upon it. Additionally, escape velocity is not an event, but rather a constant velocity that allows an object to escape the gravitational pull of a larger body.
Josielle Abdilla
50
What is the kinetic energy equal to during the escape velocity? Henceforth, what is exactly happening at the escape velocity in terms of gravity?
Escape velocity is simply the velocity required for an object to escape the gravitational pull of a body, ignoring complications like air resistance and other gravitational-influencing bodies (Sun, Moon, other planets, etc). There is no 'during'. Escape velocity is not an event.
Nothing is happening to gravity in the context of escape velocity. The object is simply traveling so fast that the gravitational acceleration of the larger body cannot decelerate the object at a fast enough rate to ever pull the object back to the surface.
Likes davenn
I would add that escape velocity decreases as altitude increases.
If you have an object exactly at escape velocity at the Earth's surface, it will still be exactly at "escape velocity" when it it 100 miles up. It will be going slower. Escape velocity 100 miles up is a bit slower than at the Earth's surface
If a quick calculation serves, escape velocity is cut approximately in half once an object is at 12,000 miles altitude (16,000 miles from the center of the Earth). Escape energy, aka potential energy deficit, scales inversely with distance from the center of the gravitating body. Quadruple the distance and you've cut energy by 1/4. So you've cut escape velocity by 1/2. The object will be moving half as fast as it was at the surface. And it will still be at escape velocity.
If it were to reach infinity without interference, an object that started at escape velocity at the Earth's surface would be at a dead stop. [Which is still equal to escape velocity because it would have already escaped]
The KE of an mass at escape velocity is such that when its added to the gravitational potential energy of the mass, the result is zero.
In other words:
$$ \frac{mv^2}{2} - \frac{GMm}{r} = 0 $$
Thus:
$$ \frac{mv^2}{2} = \frac{GMm}{r} $$
$$ v^2 = \frac{2GM}{r} $$
In other words:
Thus:
Note that this is using the definition of potential energy such that an object has zero potential at infinity, and increasingly negative potential as it approaches a massive object. This is a common definition, but certainly not the only definition, so you need to be a bit careful there.
Related to What is the kinetic energy when an object reaches escape velocity?
1. What is escape velocity?
Escape velocity is the minimum speed an object needs to reach in order to break free from the gravitational pull of a celestial body, such as a planet or moon.
2. How is escape velocity calculated?
The formula for escape velocity is v = √(2GM/r), where v is the escape velocity, G is the gravitational constant, M is the mass of the celestial body, and r is the distance from the center of the body to the object.
3. Does an object's mass affect its escape velocity?
Yes, the escape velocity of an object is directly proportional to its mass. This means that the larger the mass of the object, the higher the escape velocity required to break free from the gravitational pull.
4. Can an object have a kinetic energy greater than its escape velocity?
No, an object cannot have a kinetic energy greater than its escape velocity. This is because the escape velocity is the minimum speed required to overcome the gravitational force, and any additional kinetic energy would result in the object moving away from the celestial body at an even faster speed.
5. What happens to an object's kinetic energy after it reaches escape velocity?
Once an object reaches escape velocity, its kinetic energy remains constant. However, as it moves away from the celestial body, its potential energy increases due to the decreasing gravitational force. This results in a balance between kinetic and potential energy, allowing the object to travel through space at a constant speed.
  • Mechanics
  • Mechanics
9K
