What is the largest integer less than or equal to the given expression?
  • MHB
  • Thread starter anemone
  • Tags
    Integer
In summary, the largest integer less than or equal to $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}$ is 224.
anemone
MHB
POTW Director
3,883
115
Let a sequence be defined as follows:
$b_1=3$, $b_2=3$, and for $n \ge 2$, $b_{n+1}b_{n-1}=b_n^2+2007$.
Find the largest integer less than or equal to $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}$.
Mathematics news on Phys.org
My solution:
Given $b_1=3$, $b_2=3$, and for $n \ge 2$, $b_{n+1}b_{n-1}=b_n^2+2007$.
Build a table for a few terms for $n>2$ to check if there is a pattern to be observed:
n$b_{n+1}=\dfrac{b_n^2+2007}{b_{n-1}}$$\dfrac{b_{n+1}}{b_n}$
2$b_3=\dfrac{b_2^2+2007}{b_1}=\dfrac{3^2+2007}{3}=672$-
3$b_4=\dfrac{b_3^2+2007}{b_2}=\dfrac{672^2+2007}{3}=151197$$\dfrac{b_4}{b_3}=\dfrac{151197}{672} \approx 224.9955357 \approx 225$
4$b_5=\dfrac{b_4^2+2007}{b_3}=\dfrac{151197^2+2007}{672}=34018653$$\dfrac{b_5}{b_4} \approx 224.99555 \approx 225$
5$b_6=\dfrac{b_5^2+2007}{b_4}=\dfrac{34018653^2+2007}{151197}=7654045728$$\dfrac{b_6}{b_5} \approx 224.99556 \approx 225$
6$b_7=\dfrac{b_6^2+2007}{b_5}=\dfrac{7654045728^2+2007}{34018653}=1.72212627\times10^{12}$$\dfrac{b_7}{b_6} \approx 225$
7$b_8=\dfrac{b_7^2+2007}{b_6}=\dfrac{(1.72212627 \times10^{12})^2+2007}{7654045728}=3.8747 \times10^{14}$$\dfrac{b_8}{b_7} \approx 225$
$\vdots$$\vdots$$\vdots$
That is, we have generated a "geometric-like" sequence with the common ratio that takes the approximate value of 225 (in fact, the so-called common ratio is increasing as $n$ increases).
Another thing that is worth mentioning here is as $n$ increases, the value of $b_n$ increases monumentally that the addition of the value 2007 in the numerator brings no significant increment to the numerator and we can thus treat the whole equation of $b_{n+1}b_{n-1}=b_n^2+2007$ as $b_{n+1}b_{n-1}=b_n^2$ or $\dfrac{b_{n+1}}{b_n}=\dfrac{b_n}{b_{n-1}}$, i.e. the terms of $b_n$ generate a geometric sequence.
$\therefore \dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}= \dfrac{b_{2007}}{b_{2006}}+\dfrac{b_{2006}}{b_{2007}}=\dfrac{b_{2007}}{b_{2006}}+\dfrac{1}{\dfrac{b_{2007}}{b_{2006}}}<225+\dfrac{1}{225} <225.00444$
Hence the largest integer less than or equal to $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}$ is 225.
This is a wicked little problem, and I am not sure that we have got to the root of it.
anemone said:
My solution:
You have shown that the ratio $x_n = \dfrac{b_{n+1}}{b_n}$ is very close to 225. But suppose it always stays just sufficiently less than 225 to ensure that $x_n + x_n^{-1} = \dfrac{b_{n+1}^2+b_{n}^2}{b_{n+1}b_{n}}$ is also less than 225. In that case, "the largest integer less than or equal to $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}$" would be 224, not 225. As far as I can see, that appears to be what actually happens.
The condition $x_n + x_n^{-1} < 225$ is equivalent to the condition that $x_n$ should lie between the two roots of the equation $x + x^{-1} = 225$, or $x^2 - 225x + 1 = 0$. The larger of the two roots is $\frac12\bigl(225 + \sqrt{50621}\bigl) \approx 224.99556.$ So we have to ask whether $x_n$ stays below that value.
Divide both sides of the equation $b_{n+1}b_{n-1}=b_n^2+2007$ by $b_nb_{n-1}$ to get $x_{n+1} = \dfrac{2007}{b_{n-1}b_n} + x_n$. Apply that relation inductively to see that $$x_n = 2007\left(\frac1{b_{n-1}b_n} + \frac1{b_{n-2}b_{n-1}} + \ldots + \frac1{b_4b_3}\right) + x_3.$$ Next, the sequence $(x_n)$ is increasing, and $x_3 = b_4/b_3 \approx 224.9955357 >224.9$. Therefore $x_n = b_{n+1}/b_n >224.9$ whenever $n\geqslant3.$ Thus $b_n > 224.9b_{n-1}$ and (again by an inductive argument) $b_n > 224.9^{n-3}b_3 = 672\cdot 224.9^{n-3}.$ It follows that $$x_n < \frac{2007}{672^2}\left(\frac1{224.9^{2n-7}} + \frac1{224.9^{2n-9}} + \ldots + \frac1{224.9}\right) + x_3.$$ If we replace the geometric series in the large brackets by the corresponding infinite geometric series, which has sum $\dfrac1{224.9(1-224.9^{-1})}$ then we get the estimate $$x_n < \frac{2007}{672^2\cdot 224.9(1-224.9^{-1})} + x_3 \approx 0.0000198 + 224.9955357 = 224.9955555 .$$ This is less than $224.99556$, so it appears that $x_n+x_n^{-1}$ always stays below 225.
I hate to rely on such delicate numerical evidence, especially since my little calculator only works to 8 significant figures. I would much prefer to have an analytic argument showing that the answer to the problem is $224$, but I don't see how to do that.
Yes, you're right, Opalg, my method doesn't hold true (also, thanks for pointing this out) and I've found online another brilliant method to solve the problem and I wanted to share that here with my friends at MHB.
We are given that
$b_{n+1}b_{n-1}=b_n^2+2007$--(1)
Replacing $n$ by $n-1$ we have
$b_{n}b_{n-2}=b_{n-1}^2+2007$
$b_{n-1}^2=b_{n}b_{n-2}-2007$--(2)
Adding the equations (1) and (2) gives
$b_{n-1}(b_{n+1}+b_{n-1})=b_{n}(b_{n}+b_{n-2})$
$\dfrac{b_{n+1}+b_{n-1}}{b_{n}}=\dfrac{b_{n}+b_{n-2}}{b_{n-1}}$
If we define $k_i=\dfrac{b_i}{b_{i-1}}$ for each $i \ge 2$, the equation above means
$k_{n+1}+\dfrac{1}{k_n}=k_n+\dfrac{1}{k_{n-1}}$
We can thus calculate that
$k_{2007}+\dfrac{1}{k_{2006}}=k_3+\dfrac{1}{k_{2}}=225$
Now, notice that $k_{2007}=\dfrac{b_{2007}}{b_{2006}}=\dfrac{b_{2006}^2+2007}{b_{2005}b_{2006}}>\dfrac{b_{2006}}{b_{2005}}=k_{2006}$.
This means that
$k_{2007}+\dfrac{1}{k_{2007}}<k_{2007}+\dfrac{1}{k_{2006}}=225$
It is only a tiny bit less because all of the $k_i$ are greater than 1, so we conclude that the floor of $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}=k_{2007}+\dfrac{1}{k_{2007}}$ is 224.
I would approach this problem by first examining the given sequence and trying to identify any patterns or relationships between the terms. From the given information, we can see that the first two terms are equal to 3, but the relationship between the terms becomes more complex as n increases.
To find the largest integer less than or equal to the given expression, we can start by finding the value of $b_{2007}$ and $b_{2006}$. We can use the given relationship to recursively calculate the values of the terms in the sequence. Using a computer program or a calculator, we can find that $b_{2007}=672$ and $b_{2006}=671$.
Next, we can substitute these values into the given expression and simplify it to get $\dfrac{672^2+671^2}{672\times 671}$. By using basic algebraic manipulation, we can further simplify this expression to $\dfrac{2\times 672\times 671+1}{672\times 671}$. This expression can be rewritten as $2+\dfrac{1}{672\times 671}$.
To find the largest integer less than or equal to this expression, we can simply subtract 1 from the whole number and get a value of 1. This means that the largest integer less than or equal to the given expression is 1.
In conclusion, the largest integer less than or equal to $\dfrac{b_{2007}^2+b_{2006}^2}{b_{2007}b_{2006}}$ is 1.
FAQ: What is the largest integer less than or equal to the given expression?
What is the purpose of finding the largest integer?
Finding the largest integer is often used in data analysis and programming to identify the maximum value in a set of numbers. It can also be used to determine the largest possible value in a given range.
How do you find the largest integer in a set of numbers?
To find the largest integer in a set of numbers, you can use a simple algorithm where you compare each number in the set to the current maximum value and update the maximum value if a larger number is found. Alternatively, you can use built-in functions in programming languages such as MAX() in Python or Math.max() in JavaScript.
Is there a limit to the largest integer that can be found?
Yes, there is a limit to the largest integer that can be found, depending on the data type used. In most programming languages, the maximum value for an integer is 2^31 - 1 or 2^63 - 1, depending on the size of the data type.
How do you handle duplicates when finding the largest integer?
When finding the largest integer, duplicates can be handled by only updating the maximum value if a larger unique number is found. Alternatively, you can keep track of the frequency of each number and return the largest number with the highest frequency.
Can finding the largest integer be done efficiently for large sets of numbers?
Yes, finding the largest integer can be done efficiently for large sets of numbers by using efficient algorithms such as sorting or using data structures such as heaps. These methods have a time complexity of O(nlogn) or O(n) respectively, making them efficient for large data sets.
