What is the largest number of consecutive repeating digits in pi?
  • Thread starter MrModesty
  • Tags
    Pi
In summary, pi has been calculated to over 3 trillion decimal places and it is possible that there is a string of 3 trillion consecutive 2's in its decimal representation. However, it has not been proven that pi is a normal number, which means that every digit and sequence of digits is equally likely to appear. Proving that a number is normal is a difficult task, as shown in the proof for Champernowne's number. It is also counter-intuitive that almost all real numbers are normal, every real number is the product of two normal numbers, and multiplication by a nonzero rational number does not change the normalness of a number.
MrModesty
As far as I can tell from googling, pi has been calculated to over 3 trillion decimal places. I'm curious whether a string of 100 2's has been found.
It has to happen, right? As I understand it, we should be able to find a string of 3 trillion consecutive 2's.
Am I wrong in my thinking?
Mathematics news on Phys.org
We certainly might be able to find such a sequence but I can see no reason to think that there must be such a sequence. If, as many people believe, but I don't think has been proven, the digits of [itex]\pi[/itex] are "random" (every digit, every sequence of digits is equally likely to appear) it still does not follow that a given sequence will appear.
The notion that you're referring to is that of a normal number. A number is called normal if every finite sequence of digits occurs thesame number of times as every other finite sequence of digits. Thus in a normal number, there are as much numbers 2 as numbers 3, there are as much numbers 33 as 13.
So, in particular, in a normal number, you would expect that once in a time there would be a trillion 2's after each other.
The thing is however, that pi hasn't yet been shown to be normal. So we don't really know if there is a sequence with a trillion 2's...
A number that IS normal is Champernowne's number, this is:
0.123456789101112131415161718192021222324...
Thus just concatenate all numbers. If you concatenate all PRIME numbers, then you also get a normal number:
0.23571113171923...
This is called the Copeland-Erdos constant.
However, as you might have guessed, showing that a number is normal is very hard...
Likes Spinnor
Out of curiosity, how would one go about proving a number is normal?
0.23571113171923...
That seems counter-intuitive. Since every prime number (except two of them) ends in 1, 3, 7 or 9, one would feel the distribution was going to be biased - unless this effect washes out faster than something else, as the primes get bigger and contain more digits.
I suppose that just illustrate the fact that
A proof is found in http://www.mth.uea.ac.uk/~h720/teaching/dynamicalsystems/champernowne1933.pdf but be warned, it's not exactly easy reading...
Thanks.
I agree 100% with you, it is very counter-intuitive. In fact, if it wasn't proven, then I would have claimed that it wasn't true!
Some other counter-intuitive facts:
- almost all real numbers are normal (in the sense that the non-normal numbers have measure 0). Still it is very hard to come up with numbers which are normal.
- every real number is the product of two normal numbers
- multiplication by a nonzero rational number doesn't change the normalness of a number
FAQ: What is the largest number of consecutive repeating digits in pi?
1. What is the largest number of consecutive repeating digits in pi?
The largest number of consecutive repeating digits in pi is 12. This sequence appears at digits 762-773 and is 999999999999.
2. How many times does the largest number of consecutive repeating digits in pi occur?
The largest number of consecutive repeating digits in pi occurs only once, at digits 762-773.
3. Is the largest number of consecutive repeating digits in pi a pattern?
No, the largest number of consecutive repeating digits in pi is not considered a pattern. It is simply a sequence of numbers that occur within the infinite decimal expansion of pi.
4. Can the largest number of consecutive repeating digits in pi change?
No, the largest number of consecutive repeating digits in pi is a constant and will always be 12. The value of pi may change depending on the level of precision used, but the largest consecutive repeating digits will remain the same.
5. What significance does the largest number of consecutive repeating digits in pi hold?
The largest number of consecutive repeating digits in pi does not hold any significant mathematical or scientific meaning. It is simply an interesting fact about the number pi and its infinite decimal expansion.
