What is the Largest Possible Value of BD in a Cyclic Quadrilateral?
  • MHB
  • Thread starter anemone
In summary, a cyclic quadrilateral is a four-sided polygon with all four vertices on a common circle. The largest possible value of BD in a cyclic quadrilateral can be found by using the property that opposite angles add up to 180 degrees. Some properties of a cyclic quadrilateral include opposite angles adding up to 180 degrees, adjacent angles adding up to 180 degrees, and opposite sides being parallel. A quadrilateral can be proven to be cyclic by showing that all four vertices lie on a common circle, using properties such as opposite angles adding up to 180 degrees. It is possible for a cyclic quadrilateral to have two right angles, such as in the case of a rectangle, but not all cyclic quadrilaterals have two right angles
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $ABCD$ be a cyclic quadrilateral. The side lengths of $ABCD$ are distinct integers less than 15 such that $AB\cdot DA=BC \cdot CD$. What is the largest possible value of $BD$?
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg for his correct solution(Cool), which you can find below:
From the cosine rule in the triangle $BCD$, $$BD^2 = BC^2 + CD^2 - 2BC\cdot CD\cos(\angle BCD).$$ Similarly, in the triangle $BAD$ $$\begin{aligned}BD^2 &= BA^2 + AD^2 - 2BA\cdot AD\cos(\angle BAD) \\ &= BA^2 + AD^2 + 2BC\cdot CD\cos(\angle BCD) \end{aligned}$$ (because $BA\cdot AD = BC\cdot CD$, and $\cos(\angle BCD) = -\cos(\angle BAD)$ because opposite angles of a cyclic quadrilateral add up to $180^\circ$).
Add those two equations to get $$2BD^2 = BA^2 + AD^2 + BC^2 + CD^2.$$ So to maximise $BD^2$, we want to maximise the sum of the squares of the four sides of the quadrilateral. Thus we want to make those sides as long as possible.
Since the sides are integers less than $15$, the longest possible length for a side is $14$. Suppose that $CD = 14$. Then because $BA\cdot AD = BC\cdot CD$ it follows that $BA$ or $AD$ must be a multiple of $7$. But the only multiple of $7$ that is less than $15$ and distinct from $14$ is $7$ itself. So one of those sides, say $BA$, must be $7$. But then $\dfrac{AD}{BC} = \dfrac{CD}{BA} = \dfrac{14}7 = 2$. So the largest possible values for $AD$ and $BC$ are $12$ and $6$. Then $2BD^2 = BA^2 + AD^2 + BC^2 + CD^2 = 7^2 + 12^2 + 6^2 + 14^2 = 49+144+36+196 = 425$ and so $BD = \sqrt{425/2}\approx 14.577$.
That was on the assumption that one of the sides has length $14$. So we still have to check whether there is a better solution in which the longest side is shorter than that. There cannot be a side of length $13$ because (as in the argument above) one of the other sides would have to be a multiple of $13$, and there are no such multiples less than $15$. In the same way, there cannot be a side of length $11$. So if there is no side of length $14$ then the sum of the squares of the four sides cannot be greater than $12^2 + 10^2 + 9^2 + 8^2 = 144+100+81+64 = 389$, which is less than $425$.
In conclusion, the largest possible value of $BD$ is $ \sqrt{425/2}$.
FAQ: What is the Largest Possible Value of BD in a Cyclic Quadrilateral?
What is a cyclic quadrilateral?
A cyclic quadrilateral is a four-sided polygon where all four vertices lie on a single circle.
How do you find the largest possible value of BD in a cyclic quadrilateral?
To find the largest possible value of BD, you can use the property that the opposite angles in a cyclic quadrilateral add up to 180 degrees. By finding the angle measures of the other three angles, you can determine the measure of angle BD and use trigonometry to find the length of BD.
What is the property of a cyclic quadrilateral that allows us to find the largest possible value of BD?
The property that allows us to find the largest possible value of BD is that the opposite angles in a cyclic quadrilateral add up to 180 degrees.
Can the largest possible value of BD be determined without knowing the angle measures of the other three angles?
No, the largest possible value of BD cannot be determined without knowing the angle measures of the other three angles. This is because the angle measures are necessary to calculate the measure of angle BD and the length of BD using trigonometry.
What is the significance of finding the largest possible value of BD in a cyclic quadrilateral?
Finding the largest possible value of BD can help us to determine the maximum area of a cyclic quadrilateral. It can also be useful in solving various geometry problems and applications.
