What is the length of DC in this trapezium?
  • MHB
  • Thread starter mathlearn
  • Tags
    Dc Length
In summary, to find the length of $\overline{DC}$ in a trapezium with sides $\overline{AB} = (x + 3)$ cm, $\overline{DC} = (2x − 3)$ cm, and $\overline{BE} = \overline{EC}$, where the area is 15 cm2, the value of $x$ can be found by setting up the equation $15 = \dfrac{((x+3)+(2x-3))h}{2}$ and solving for $x$. The height, $h$, can then be found by setting $h=(2x-3)-(x+3)$ and solving for $h$
mathlearn
331
In the trapezium ABCD shown in the figure, AB = (x + 3) cm, DC = (2x − 3) cm and BE = EC. If the area of the trapezium is 15 cm2, find the length of DC to the nearest first decimal place.
Take $\sqrt{19}$ = $4.36$
Have I done correctly,
Okay first we know that area of a trapezium
$h=(2x-3) -(x+3)$ $h=2x-3 -1(x+3)$
$h=2x-3 -x-3$
$h=x-3 -3$
$h=x-6$
, Correct ?
Many Thanks :)
Mathematics news on Phys.org
Start with
$$\dfrac{(2x-3+x+3)h}{2}=15\implies hx=10$$
and
$$2x-3-h=x+3$$
Can you continue?
$2x−3−h=x+3$
As I have found earlier,
greg1313 said:
$$2x-3-h=x+3$$
Can you continue?
$h=x−6$
\(\displaystyle \therefore\) $2x−3-x-3=h$, $x-6=h$
$15 = \dfrac{((x+3)+(2x-3))*(x-6)}{2}$
$30= {(3x)*(x-6)}$
$30= {(3x^2-18x)}$
$10= {(x^2-6x)}$
Okay from there on I will factor using complete the square method,
$10+ \frac{b}{2}^2= {(x^2-6x)+\frac{b}{2}^2}$
$10+ \frac{-6}{2}^2= {(x^2-6x)+\frac{-6}{2}^2}$
$10+ 9= {(x^2-6x)+9}$
$19 = {(x^2-6x)+9}$
Now factorising
\(\displaystyle \sqrt{19}\)= $\sqrt{(x-3)^2}$
The problem has given the value of \(\displaystyle \sqrt{19}\)= 4.36;
\(\displaystyle 4.36\)= $(x-3)$
\(\displaystyle 7.36\)= $x$
Now have I done correct ? :)
$$hx=10\implies h=\dfrac{10}{x}$$
$$2x-3-h=x+3$$
$$2x-3-\dfrac{10}{x}=x+3$$
$$2x^2-3x-10=x^2+3x$$
$$\implies x^2-6x-10=0$$
$$\implies x=\dfrac{6+\sqrt{76}}{2}=3+\sqrt{19}$$
$$2x-3=2(3+\sqrt{19})-3=3+2\sqrt{19}\approx11.7\text{ cm.}$$
$2x-3=2(3+\sqrt{19})-3=3+2\sqrt{19}\approx11.7\text{ cm.}$. A Little explanation here please? :)
Many Thanks :)
Another approach would be to let:
\(\displaystyle \overline{DC}=u\)
thus:
\(\displaystyle \overline{AB}=\frac{u+9}{2}\)
Now compute the area two ways:
\(\displaystyle A=\frac{h}{2}(u+9)+\frac{1}{2}h^2=\frac{h}{2}(u+h+9)\)
\(\displaystyle A=\frac{h}{2}\left(u+\frac{u+9}{2}\right)=\frac{h}{2}\left(\frac{3u+9}{2}\right)\)
Hence:
\(\displaystyle 3u+9=2u+2h+18\)
\(\displaystyle h=\frac{u-9}{2}\)
Thus:
\(\displaystyle \frac{u-9}{8}(3u+9)=15\)
\(\displaystyle (u-9)(u+3)=40\)
\(\displaystyle u^2-6u-67=0\)
Taking the positive root, we obtain:
\(\displaystyle u=3+2\sqrt{19}\)
Hi but I cannot still understand $\displaystyle u=3+2\sqrt{19}$ .
$h=2x-3 -x-3$
$h=x-3 -3$
$h=x-6$
, Correct ?
Many Thanks :)
There is a simpler way to find [tex]h = BE.[/tex]
Note that [tex]DE = AB = x+3.[/tex]
Also: [tex]\underbrace{DC}_{2x-3} \:=\: \underbrace{DE}_{x+3} + EC[/tex]
Hence, [tex]EC = BE= x-6[/tex]
Where did I lose you? :)
:) So far I have found the height or 'h' but after factoring using the complete the square method i get the square root of 19 or 4.36 as x-3 so I find that x is 7.36 But I know I have missed a factor 2 on the of $\sqrt{19}$.
I want to know where does that 2 come from and why I am missing it?
Many Thanks :)
mathlearn said:
$2x−3−h=x+3$
$h=x−6$
$30= {(3x)*(x-6)}$
$30= {(3x^2-18x)}$
$10= {(x^2-6x)}$
$19 = {(x^2-6x)+9}$
Now factorising
You have correctly found $x$. $\overline{DC}=2x-3=2(7.36)-3=14.72-3=11.72$.
Many Thanks :)
The '2' comes from $\overline{DC}=2(3+\sqrt{19})-3=6+2\sqrt{19}-3=3+2\sqrt{19}$. You're confusing $x$ and $\overline{DC}$.
FAQ: What is the length of DC in this trapezium?
How do I find the length of DC using the Pythagorean Theorem?
The Pythagorean Theorem states that in a right triangle, the square of the length of the hypotenuse (longest side) is equal to the sum of the squares of the other two sides. In this case, we can set up the equation a^2 + b^2 = c^2, where a and b are the lengths of the other two sides and c is the length of the hypotenuse. Simply plug in the known values and solve for c (DC).
Can I use trigonometry to find the length of DC?
Yes, you can use trigonometry to find the length of DC. Since we know two angles of the right triangle (90 degrees and 30 degrees), we can use the sine function to find the length of DC. The formula is sin(30) = opposite/hypotenuse. In this case, the opposite side is 5 cm and the hypotenuse is DC, so we can rearrange the formula to solve for DC.
What if I only know the length of one side and one angle of the right triangle?
If you only know the length of one side and one angle of the right triangle, you can still use trigonometry to find the length of DC. In this case, you would use the tangent function, which is tan(30) = opposite/adjacent. The adjacent side is the known side, and the opposite side is DC. Again, you can rearrange the formula to solve for DC.
Is there another method besides using the Pythagorean Theorem or trigonometry?
Yes, there are other methods to find the length of DC. One method is to use the Law of Cosines, which states that c^2 = a^2 + b^2 - 2abcos(C), where C is the angle opposite of side c. In this case, we can set up the equation and solve for c (DC). Another method is to use the Law of Sines, which states that sin(A)/a = sin(B)/b = sin(C)/c. You can use this formula to find the length of DC by setting up the proportion and solving for c.
Can I use a calculator to find the length of DC?
Yes, you can use a calculator to find the length of DC. Most scientific calculators have functions for trigonometry and square roots, making it easy to plug in the values and solve for DC. Just make sure your calculator is set to the correct degree or radian mode when using trigonometric functions.
