What is the Limit as x Approaches 0 for the Absolute Value Function?
  • MHB
  • Thread starter karush
  • Tags
    Limit
In summary: We can rewrite this as\lim_{x\to0}\dfrac{d}{dx}\,\left|f(x)\right|=-\lim_{x\to0}\dfrac{f'(x)}{\left|f(x)\right|}.Now, we can use the following identities:\lim_{x\to0}\dfrac{d}{dx}\,\left|f(x)\right|=\dfrac{f'(x)}{\left|f(x)\right|}=-\lim_{x\to0}\dfrac{d}{dx}\,f(x)=-\lim_{x\to0
karush
MHB
3,269
$$\lim_{{x}\to{0}}\frac{\left| 2x-1 \right|-\left| 2x+1 \right|}{x}=-4$$
I tried /x but couldn't get the answer
Since we have the absolute values we have to look at which points the expressions $2x-1$ and $2x+1$ change the sign.
We have that $2x-1>0$ for $x>\frac{1}{2}$ and $2x+1>0$ for $x>-\frac{1}{2}$.
Since we want to calculate the limit as $x \rightarrow 0$, we have to take the case $-\frac{1}{2}<x<\frac{1}{2}$.
So we have the following: $$\lim_{x \rightarrow 0}\frac{|2x-1|-|2x+1|}{x}=\lim_{x \rightarrow 0}\frac{-(2x-1)-(2x+1)}{x}\\ =\lim_{x \rightarrow 0}\frac{-2x+1-2x-1}{x}=\lim_{x \rightarrow 0}\frac{-4x}{x}\\ =\lim_{x \rightarrow 0}-4=-4$$
I don't see why you choose the - sign
We have the following identity of an absolute value:
$$|a|=\left\{\begin{matrix}
a \ \ ,& a>0\\
-a \ \ ,& a<0
\end{matrix}\right.$$
For $x>\frac{1}{2}$ we have that $2x-1$ is positive, so $|2x-1|=2x-1$.
For $x<\frac{1}{2}$ we have that $2x-1$ is negative, so $|2x-1|=-(2x-1)$.
Since we choose the interval $-\frac{1}{2}<x<\frac{1}{2}$ we have that $|2x-1|=-(2x-1)=-2x+1$.
Got it
I suggest to prove the following:
\(\displaystyle \forall \epsilon>0\exists\delta>0\forall x\in\mathbb{R}^*\left(|x|<\delta\to\left|\frac{|2x-1|-|2x+1|}{x}+4\right|<\epsilon\right)\)
which defines
\(\displaystyle \lim_{x\to 0}\frac{|2x-1|-|2x+1|}{x}=-4.\)
which defines
Rather daunting!
L'Hopital's rule:
\(\displaystyle \lim_{x\to0}\dfrac{\left|2x-1\right|-\left|2x+1\right|}{x}=\lim_{x\to0}\dfrac{2(2x-1)}{\left|2x-1\right|}-\dfrac{2(2x+1)}{\left|2x+1\right|}=\lim_{x\to0}-2-2=-4\)
Using the chain rule, \(\displaystyle \dfrac{d}{dx}\,\left|f(x)\right|=f'(x)\dfrac{f(x)}{\left|f(x)\right|}\).
FAQ: What is the Limit as x Approaches 0 for the Absolute Value Function?
What does it mean for x to approach 0?
When we say that x is approaching 0, it means that the value of x is getting closer and closer to 0, but not quite reaching it. In other words, x is getting infinitely close to 0.
What is the significance of taking the limit as x approaches 0?
Taking the limit as x approaches 0 allows us to understand the behavior of a function as the input value gets closer to 0. This can help us determine the value of the function at 0 or how it behaves near 0.
How do we calculate the limit as x approaches 0?
To calculate the limit as x approaches 0, we substitute 0 for x in the given function and simplify the resulting expression. This will give us the value that the function is approaching as x gets closer to 0.
What does it mean for a limit to approach a specific number, in this case -4?
If the limit as x approaches 0 is -4, it means that as x gets closer and closer to 0, the value of the function is approaching -4. In other words, the function is getting infinitely close to -4 at x=0.
Can the limit as x approaches 0 be different from the value of the function at 0?
Yes, the limit as x approaches 0 and the value of the function at 0 can be different. This can happen when the function has a point of discontinuity or a hole at x=0. In this case, the limit does not exist at x=0, but the function may still have a defined value at x=0.
