What is the limit of (ln n)^n / [ln(n+1)]^(n+1) as n approaches infinity?
  • MHB
  • Thread starter alexmahone
  • Tags
    Limit
In summary: There is nothing to complete. You have a bounded factor and a factor the limit of which is $=?$.In summary, the limit of the sum $\displaystyle \lim_{n\to\infty}\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}$ is zero.
alexmahone
304
Find $\displaystyle \lim_{n\to\infty}\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}$.
Is...
$\displaystyle \frac{\ln n}{\ln (n+1)} = 1+ \frac{\ln n - \ln (n+1)}{\ln (n+1)} \implies \lim_{n \rightarrow \infty} (\frac{\ln n}{\ln (n+1)})^{n}=1 \implies$
$\displaystyle \implies \lim_{n \rightarrow \infty} \frac{1}{\ln (n+1)}\ (\frac{\ln n}{\ln (n+1)})^{n}=0$
Kind regards
$\chi$ $\sigma$
$\displaystyle\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}=\frac{1}{\ln(n+1}\left[\frac{\ln(n)}{\ln(n+1)}\right]^n$.
If $n\ge 3$ then $\displaystyle\left[\frac{\ln(n)}{\ln(n+1)}\right]<1$.
Plato said:
$\displaystyle\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}\frac{1}{\ln(n+1}\left[\frac{\ln(n)}{\ln(n+1)}\right]^n$.
Actually, $\displaystyle\left[\frac{\ln(n)}{\ln(n+1)}\right]<1$ for $n\ge 1$.
How does that effect the truth of what I posted?
Let us define the following infinite sum:
$$\sum_{n=1}^{\infty} \frac{(\ln n)^n}{[\ln (n+1)]^{n+1}} $$
That sum is converges, use Cauchy root test, hence,
$$\lim_{n\to\infty}\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}=0$$
How did you conclude that $\displaystyle\lim_{n\to\infty} \left(1+ \frac{\ln n - \ln (n+1)}{\ln (n+1)}\right)^n=1$?
It doesn't, but you didn't complete your proof. $\displaystyle 1^\infty$ is an indeterminate form.
If I am not mistaken, $\sqrt[n]{\frac{(\ln n)^n}{[\ln (n+1)]^{n+1}}}\to1$ as $n\to\infty$, so the test is inconclusive.
zero
Because is...
$\displaystyle (1+o(n))^{n}= 1 + n\ o(n) + \binom {n}{2}\ o^{2}(n)+...+ \binom{n}{n-1}\ o^{n-1}(n) + o^{n}(n)$ (1)
... You have that...
$\displaystyle \lim_{n \rightarrow \infty} n\ o(n)=0 \implies \lim_{n \rightarrow \infty}(1+o(n))^{n}=1$ (2)
For n 'large enough' is...
$\displaystyle \ln (n+1)-\ln n \sim \frac{1}{n} \implies o(n)= \frac{\ln n - \ln (n+1)}{\ln (n+1)} \sim - \frac{1}{n\ \ln (n+1)}$ (3)
... so that the (2) is verified...
Kind regards
$\chi$ $\sigma$
By the definition of small-o, $f(n)$ is $o(n)$ if $f(n)/n\to 0$, not $nf(n)\to0$. Also, $1/n$ is $o(1)$ and $o(n)$, but $(1+1/n)^n\to e$ as $n\to\infty$.
FAQ: What is the limit of (ln n)^n / [ln(n+1)]^(n+1) as n approaches infinity?
What is "Another limit"?
"Another limit" refers to a concept in mathematics and physics, specifically in the field of calculus. It is a mathematical expression that represents the value that a function or sequence approaches as the input or index approaches a certain number or value.
Why is "Another limit" important?
"Another limit" is important because it allows us to understand and analyze the behavior of a function or sequence at a certain point or value. It also helps us to solve complex problems in mathematics and physics, such as finding the maximum or minimum value of a function.
How is "Another limit" calculated?
"Another limit" is calculated using the limit notation, which is represented by the symbol "lim". The limit of a function or sequence is calculated by evaluating the function at values approaching the desired point or value. This process is often done using algebraic manipulation or graphical analysis.
What are the different types of "Another limit"?
There are several types of limits, including one-sided limits, infinite limits, and limits at infinity. One-sided limits are evaluated from one direction (either from the left or the right) while infinite limits occur when the function approaches positive or negative infinity. Limits at infinity occur when the input or index approaches infinity.
How do scientists use "Another limit" in their research?
Scientists use "Another limit" in their research to analyze and model various phenomena in the natural world. For example, limits are used in physics to calculate the velocity and acceleration of an object at a particular point in time. In biology, limits are used to model population growth and decay. In chemistry, limits are used to determine the concentration of a substance in a solution. Basically, limits are used in any field of science that involves the study of continuous change.
