What is the Limit of the Hankel Determinant in a Matrix Challenge Problem?
In summary, the problem is to show that the limit as n approaches infinity of the determinant of the Hankel matrix H(n) raised to the power of 1/n is equal to the product of the absolute values of the eigenvalues of the matrix A. This can be proved by using the fact that A is diagonalizable and applying the Newton sum formula to the final column of H(n). This leads to the conclusion that the determinant of H(n) is equal to a constant multiple of the determinant of H(r), which can be shown to be equal to the product of the eigenvalues. Thus, the limit is equal to this product, proving the desired result.
MountEvariste
87
Challenge Problem: Let $A$ be an $r \times r$ matrix with distinct eigenvalues $λ_1, . . . , λ_r$. For $n \ge 0$, let $a(n)$ be
the trace of $A^n$. Let $H(n)$ be the $r \times r$ the Hankel matrix with $(i, j)$ entry $a(i + j + n - 2)$. Show that
$ \displaystyle
\lim_{n \to \infty}
\lvert \det H(n) \rvert ^{1/n} =\prod_{k=1}^{r} \lvert \lambda_k \rvert
Mathematics news on Phys.org
the trace of $A_n$. Let $H(n)$ be the $r \times r$ the Hankel matrix with $(i, j)$ entry $a(i + j + n - 2)$. Show that
$$\lim_{n \to \infty} \lvert \det H(n) \rvert ^{1/n} =\prod_{k=1}^{r} \lvert \lambda_k \rvert .$$
I'm assuming that $A_n$ in the statement of the problem should be $A^n$.
[sp]Since $A$ has distinct eigenvalues, it is diagonalizable. So its trace is $\lambda_1 + \ldots + \lambda_r$ and the trace of $A^n$ is $a(n) = \lambda_1^n + \ldots + \lambda_r^n$.
Let $x^r + c_1x^{r-1} + \ldots + c_{r-1}x + c_r = 0$ be the equation whose roots are $\lambda_1, \ldots, \lambda_r$. Apply the Newton sum formula $a(k) + c_1a(k-1) + \ldots + c_ra(k-r) = 0$ to each element of the final column of $H(n)$ (where $n>r$) to get $$\begin{aligned}\det H(n) &= \begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & a(n+r-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & a(n+r) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & a(n + 2r-2) \end{vmatrix} \\ \\ &= \begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & -c_1a(n+r-2) - \ldots - c_{r-1}a(n) - c_ra(n-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & -c_1a(n+r-1) - \ldots - c_{r-1}a(n+1) - c_ra(n) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & -c_1a(n+2r-3) - \ldots - c_{r-1}a(n+r-1) - c_ra(n+r-2) \end{vmatrix}. \end{aligned}$$ For each $k$ with $1\leqslant k\leqslant r-1$, add $c_{r-k}$ times the $k$th column of that determinant to the last column, giving $$\det H(n) = -c_r\begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & a(n-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & a(n) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & a(n + r-2) \end{vmatrix}.$$ But that determinant is just $\det H(n-1)$ with the first column shifted all the way to the right. This shows that $\det H(n) = \pm c_r\det H(n-1)$. By induction, $\det H(n) = \pm c_r^{n-r}\det H(r)$.
Therefore \(\displaystyle |\det H(n)|^{1/n} = |c_r|\left|\frac{\det H(r)}{c_r^r}\right|^{1/n} \to |c_r|\) as $n\to\infty$. But $c_r$ is $\pm$ the product of the roots of the equation $x^r + c_1x^{r-1} + \ldots + c_{r-1}x + c_r = 0$, namely \(\displaystyle \prod_{k=1}^r\lambda_k.\) So \(\displaystyle \lim_{n\to\infty}|\det H(n)|^{1/n} = \prod_{k=1}^r|\lambda_k|\), as required.
[/sp]
Opalg said:
Thanks for such a beautiful solution! (Bow)
Yeah, indeed I meant $A^n$. Fixed now.
FAQ: What is the Limit of the Hankel Determinant in a Matrix Challenge Problem?
What is a Hankel Determinant Limit?
A Hankel determinant limit is a mathematical concept that involves taking the limit of a sequence of determinants of Hankel matrices, which are square matrices with constant values along each diagonal. This limit can provide information about the underlying sequence and its behavior.
How is a Hankel Determinant Limit calculated?
The Hankel determinant limit is calculated by taking the limit as n approaches infinity of the determinant of an n x n Hankel matrix. This can be done by using mathematical techniques such as the Cauchy-Binet formula or by using properties of Hankel matrices to simplify the calculation.
What is the significance of a Hankel Determinant Limit?
The Hankel determinant limit has applications in various fields such as number theory, signal processing, and pattern recognition. It can provide information about the long-term behavior of a sequence and can be used to identify patterns or trends within the sequence.
Are there any limitations to using a Hankel Determinant Limit?
While the Hankel determinant limit can provide valuable insights, it is not always applicable to every sequence or matrix. It requires the sequence to have certain properties, and the limit may not exist or may not accurately represent the behavior of the sequence in some cases.
How is a Hankel Determinant Limit different from other types of limits?
A Hankel determinant limit is specific to sequences and matrices that follow a certain pattern and cannot be applied to general functions or series. It also involves a unique calculation method using determinants of Hankel matrices, which sets it apart from other types of limits such as the limit of a function or the limit of a sequence of numbers.
18K
11K
9K
12K
9K
