What is the limit of the sequence {$a_n$}?
In summary, the conversation is about finding the limit of a sequence defined by $a_1 = 1$ and $a_n = \frac{1}{1+a_{n-1}}$ for $n \geq 2$. The difference equation is $\Delta_n = \frac{1-a_n-a_n^2}{1+a_n}$ and the only attractive fixed point is $\xi = \frac{\sqrt{5}-1}{2}$. Therefore, the sequence tends to $\xi$ for any $x_0>-1$.
lfdahl
MHB
749
Let the sequence {$a_n$} be defined by $a_1 = 1$ and $a_n = \frac{1}{1+a_{n-1}}$
for $n \ge 2$ . Find the limit.
Mathematics news on Phys.org
lfdahl said:
Let the sequence {$a_n$} be defined by $a_1 = 1$ and $a_n = \frac{1}{1+a_{n-1}}$ for $n \ge 2$ . Find the limit.
[sp]The difference equation can be written as... $\displaystyle \Delta_{n} = a_{n=1} - a_{n} = \frac {1}{1 + a{n}} - a_{n}= \frac{1 - a_{n} - a^{2}_{n}}{1 + a_{n}}= f(a_{n})\ (1)$ ... and there is the only attractive fixed point of f(x) in $\displaystyle \xi = \frac {\sqrt{5}-1}{2} = .618...$, so that for any $x_{0}> - 1$ he sequence tends to $\xi$...[/sp] Kind regards $\chi$ $\sigma$
Thankyou, chisigma, for your valuable and correct contribution!:cool:
The thread is still open for alternative approaches.
Substitute $a_n$ repeatedly i.e
$$a_n=\frac{1}{1+a_{n-1}}=\frac{1}{1+\frac{1}{1+a_{n-2}}}=\frac{1}{1+\frac{1}{1+\frac{1}{1+\cdots}}}$$
Since $n\rightarrow \infty$, we can write:
$$a_n=\frac{1}{1+a_n}$$
$$\Rightarrow a_n^2+a_n-1=0$$
$$\Rightarrow a_n=\frac{\sqrt{5}-1}{2}$$
Correct, short and consistent solution Pranav. Well done!(Nod)
FAQ: What is the limit of the sequence {$a_n$}?
What is a sequence?
A sequence is a list of numbers that follow a specific pattern or rule. The numbers in a sequence are called terms and are identified by their position in the sequence.
How do you find the limit of a sequence?
To find the limit of a sequence, you need to determine what value the terms in the sequence approach as the position in the sequence gets larger and larger. This can be done by calculating the values of the terms in the sequence or by using mathematical techniques such as the squeeze theorem or the ratio test.
Why is finding the limit of a sequence important?
Finding the limit of a sequence is important because it helps us understand the behavior of a sequence as it approaches infinity. This is a key concept in calculus and is used to solve many real-world problems in physics, engineering, and other fields.
Can the limit of a sequence be infinite?
Yes, the limit of a sequence can be infinite. This means that as the terms in the sequence get larger and larger, there is no upper bound or limit to their values. In this case, we say that the sequence diverges.
How is the limit of a sequence related to the limit of a function?
The limit of a sequence and the limit of a function are closely related. In fact, the limit of a function can be thought of as the limit of a sequence of values at different points on the graph of the function. As the x-values approach a certain value, the corresponding y-values approach the limit of the function at that point.
