What is the Limit of the Sequence Defined by \( z_{n+1}=\sqrt{a+z_n} \)?
  • MHB
  • Thread starter issacnewton
  • Tags
    Section
In summary, the problem is to show that the sequence defined by $z_{n+1}=\sqrt{a+z_n}$ for $n\in\mathbb{N}$, where $a>0$ and $z_1>0$, converges and to find its limit using the monotone convergence theorem. To do this, we need to prove that the sequence is bounded and monotone. We can prove that it is bounded below by 0, but we need to find an upper bound. Depending on the values of $a$ and $z_1$, the sequence can be either increasing or decreasing. Using the properties of the function $f(x)=\sqrt{a+x}-x$, we can show
issacnewton
1,041
37
here is the problem.
Let \( a>0\) and \( z_1 > 0\) . define \( z_{n+1}=\sqrt{a+z_n} \) for all \( n\in \mathbb{N} \). Show that \( (z_n) \) converges and find the limit.
I am supposed to use monotone convergence theorem. For that I need to prove that the sequence is bounded and monotone. I can prove that its bounded below by \( 0 \), but I am having trouble about the upper bound. Also sequence can be increasing or decreasing, depending upon the values
of \( a\) and \( z_1 \) . Any hints ?
Let's suppose that z is real and let's write the recursive relation as...
$\displaystyle \Delta_{n+1}= z_{n+1}-z_{n}= \sqrt{a+z_{n}}-z_{n}= f(z_{n})\ ,\ a>0\ ,\ z_{0}>0$ (1)
In this case f(x) has two 'fixed points' [points where is f(x)=0...], an 'attractive fixed point' at $\displaystyle x_{+}= \frac{1+\sqrt{1+4 a}}{2}$ and a 'repulsive fixed point' at $\displaystyle x_{-}= \frac{1-\sqrt{1+4 a}}{2}$. The combined conditions $a>0$ and $z_{0}>0$ imply that in any case the sequence converges to $x_{+}$, if $0<z_{0}<x_{+}$ the sequence will be 'monotonically increasing', if $z_{0}=x_{+}$ the sequence will be constant, if $z_{0}>x_{+}$ the sequence will be 'monotonically decreasing'...
Kind regards
$\chi$ $\sigma$
Let us first consider the case when $\displaystyle z_1<\frac{1+\sqrt{1+4a}}{2}$.
Step 1: Assume $\displaystyle z_n<\frac{1+\sqrt{1+4a}}{2}$ and show that $\displaystyle z_{n+1}<\frac{1+\sqrt{1+4a}}{2}$. This will prove (by induction) that $\displaystyle \{z_n\}$ is bounded above.
Step 2: $\displaystyle \frac{z_{n+1}}{z_n}=\sqrt{\frac{a+z_n}{z_n^2}}= \sqrt{\frac{a}{z_n^2}+\frac{1}{z_n}}$
Using $\displaystyle z_n<\frac{1+\sqrt{1+4a}}{2}$ (proved in step 1), show that $\displaystyle \frac{z_{n+1}}{z_n}>1$. This will prove that $\displaystyle \{z_n\}$ is increasing.
This is chapter on sequences and the book has not done functions yet. I just want to assume the things which the book assumes at this point.
So with the information given, I think its better to split the problem in 3 cases, depending upon where \( z_1 \) is with respect to \( x_{+} \).
Step 2: $\displaystyle \frac{z_{n+1}}{z_n}=\sqrt{\frac{a+z_n}{z_n^2}}=sqrt\left(\frac{a}{z_n^2}+\frac{1}{z_n}\right)$
Step 2*:
True(induction hypothesis) : $z_{n+1}>z_{n}$
Need to prove:
$$ z_{n+2}>z_{n+1}$$$$z_{n+2}=\sqrt{a+z_{n+1}}>\sqrt{a+z_n}=z_{n+1}$$
Also sprach Zarathustra said:
Step 2*:
Need to prove:
What about the base case?
Let's write again the recursive relation in term of difference equation...
$\displaystyle \Delta_{n}=z_{n+1}-z_{n}= \sqrt{a+z_{n}}-z_{n}= f(z_{n})\ ,\ a>0\ ,\ z_{0}>0$ (1)
In order to have a simple description of the problem the function $\displaystyle f(x)=\sqrt{a+x}-x$ for $a=1$ is represented here...
The f(x) has only one 'attractive fixed point' [a point where is f(x)=0 and the function crosses the x axes with negative slope...] in $\displaystyle x_{+}= \frac{1+\sqrt{5}}{2}$ and it is evident that, because is $\displaystyle |f(x)|< |x-x_{+}|$ [see 'red line'...], any $0<z_{0}< x_{+}$ will generate an increasing sequence with limit $x_{+}$ and any $z_{0}> x_{+}$ will generate a decreasing sequence with limit $x_{+}$...
Kind regards
$\chi$ $\sigma$
Thanks all. Solved the problem as suggested.
FAQ: What is the Limit of the Sequence Defined by \( z_{n+1}=\sqrt{a+z_n} \)?
What is Bartle problem 6 section 3.3?
Bartle problem 6 section 3.3 is a mathematical problem that was proposed by Richard Bartle in his book "Designing Virtual Worlds". It involves creating a system of rules and interactions for players in a virtual world.
What is the purpose of Bartle problem 6 section 3.3?
The purpose of Bartle problem 6 section 3.3 is to explore different player motivations and behaviors within a virtual world. It allows game designers to create a balanced and engaging experience for players.
What are the four player types in Bartle problem 6 section 3.3?
The four player types in Bartle problem 6 section 3.3 are achievers, explorers, socializers, and killers. These types represent different motivations and goals that players have within a virtual world.
How does Bartle problem 6 section 3.3 impact game design?
Bartle problem 6 section 3.3 has a significant impact on game design as it helps designers understand player motivations and behaviors. By considering the four player types, designers can create a more immersive and enjoyable experience for players.
Can Bartle problem 6 section 3.3 be applied to real-world scenarios?
Yes, Bartle problem 6 section 3.3 can be applied to real-world scenarios such as online communities or social media platforms. It can help in understanding and managing user interactions and behaviors in these environments.
