What is the limit of this expression as n approaches infinity?
  • MHB
  • Thread starter aruwin
  • Tags
    Root Test
In summary: I haven't done l'hopitals rule in a while so I read about it on wiki. But the simplification method is much easier. That means the limit is 1/e,
aruwin
208
Hello.
How do I find the limit of this term?
$$\lim_{{n}\to{\infty}}|\left(\frac{n}{n+1}\right)^{\!{n^2}}|^\frac{1}{n}$$
aruwin said:
Hello.
Well for starters, how can you simplify this expression?
This is how it is simplified (I skipped the lim symbol)$\left(\frac{n}{n+1}\right)^{\!{n}}$
Yes. So now I would think about if it's possible to get it in the form $\displaystyle \begin{align*} \frac{0}{0} \end{align*}$ or $\displaystyle \begin{align*} \frac{\infty}{\infty} \end{align*}$ so that I can use L'Hospital's Rule.
To do this, write it as
$\displaystyle \begin{align*} \left( \frac{n}{n + 1} \right) ^n = \mathrm{e}^{ \ln{ \left[ \left( \frac{n}{n+1} \right) ^n \right] } } \end{align*}$
Now try to simplify it using logarithm laws.
What would $\frac{0}{0}and \frac{\infty}{\infty}$ mean?
They are meant to indicate that both numerator and denominator tend to $0$ respectively $\infty$. This is a precondition to apply l'Hopitals rule.
Instead of applying l'Hopitals rule, you can also simplify further to:
$$\lim_{n\to \infty} \frac{1}{\left(1+\frac{1}{n}\right)^{\!{n}}}$$
Now you can make use of the standard limit:
$$\lim_{n\to \infty} \left(1+\frac{1}{n}\right)^{\!{n}} = e$$
I like Serena said:
They are meant to indicate the both numerator and denominator tend to $0$ respectively $\infty$. This is a precondition to apply l'Hopitals rule.
Thanks!
You can also write $$\left( \frac{n}{n+1} \right)^n = \left( \frac{n+1-1}{n+1} \right)^n = \left( 1 - \frac{1}{n+1} \right)^n$$ and deduce the limit from here. :)
FAQ: What is the limit of this expression as n approaches infinity?
1. What does the limit of an expression mean?
The limit of an expression is a fundamental concept in calculus that describes the behavior of a function as its input approaches a specific value, often infinity or negative infinity. It represents the value that the function approaches, but may never actually reach, as the input gets closer and closer to the specific value.
2. How do you find the limit of an expression?
To find the limit of an expression as n approaches infinity, you can use various techniques such as direct substitution, factoring, and algebraic manipulation. In some cases, you may need to use more advanced methods like L'Hopital's rule or the squeeze theorem.
3. Can the limit of an expression be undefined?
Yes, the limit of an expression can be undefined. This can happen if the expression has a vertical asymptote, where the function approaches positive or negative infinity as the input approaches a certain value. It can also occur if the expression has a discontinuity, where the function has a sudden jump or gap in its graph.
4. What is the difference between a one-sided and two-sided limit?
A one-sided limit only considers the behavior of the function as the input approaches the specific value from one direction (either positive or negative). A two-sided limit looks at the behavior of the function from both directions as the input approaches the specific value. In most cases, if the one-sided limits are equal, then the two-sided limit exists and is equal to the one-sided limits.
5. Why is it important to understand limits in mathematics?
Limits are important in mathematics because they allow us to describe the behavior of functions and analyze their properties. They are also used in various applications, such as finding the maximum or minimum values of a function, calculating rates of change, and determining convergence or divergence of series.
