What is the limit of x^n/n as n approaches infinity?
  • MHB
  • Thread starter Dethrone
  • Tags
    Limit
In summary, the theorem asserts that if the limit:\lim_{n\to\infty}\frac{a_{n+1}-a_{n}}{b_{n+1}-b_{n}}=Lexists, then the limit:\lim_{n\to\infty}\frac{a_{n}}{b_{n}}=Lalso exists and is equal to $L$.
Dethrone
717
Prove that $\lim_{{n}\to{\infty}}\frac{x^n}{n!}=0$.
Mathematics news on Phys.org
There are so many ways to approach this but here's a funny way.
Since the series $\sum_{n = 0}^\infty x^n/n!$ converges to $e^x$ for all $x$, by the $n$th term test, $\lim_{n\to \infty} x^n/n! = 0$ for all $x$.
Assume that $x>0$
$$\frac{x^n}{n!} \leq \frac{k^n}{n!} \leq \frac{k^k}{k!}\times \frac{k}{n}\, \to 0 $$[/sp]
My solution:
By the Stolz–Cesàro theorem, we may state:
\(\displaystyle \lim_{n\to\infty}\frac{x^n}{n!}=\lim_{n\to\infty}\frac{x^{n+1}-x^n}{(n+1)!-n!}=\lim_{n\to\infty}\left(\frac{x^n}{n!}\cdot\frac{x-1}{n}\right)=\left(\lim_{n\to\infty}\frac{x^n}{n!}\right)\cdot0=0\)
[sp]The safest way, in the sense that You avoid possible logical vicious circles, consists of 'merely attacking' ...
$\displaystyle \frac{x^{n}}{n!} = \frac{x}{n}\ \frac{x}{n-1} ... \frac{x}{2}\ x\ (1)$
... and the limit of (1) if n tends to infinity is quite obvious...[/sp]
Kind regards
$\chi$ $\sigma$
Using Stirling's approximation,
\(\displaystyle \lim_{n\to\infty}\frac{x^n}{n!}\)
\(\displaystyle =\lim_{n\to\infty}\frac{x^n}{\sqrt{2\pi n}\left(\frac{n}{e}\right)^n}\)
\(\displaystyle =\lim_{n\to\infty}\left[\frac{1}{\sqrt{2\pi n}}\cdot\left(\frac{ex}{n}\right)^n \right]=0\)
MarkFL said:
My solution:
I don't think this is a valid proof since you are assuming that the limit exists.
The Stolz–Cesàro theorem asserts that if the limit:
\(\displaystyle \lim_{n\to\infty}\frac{a_{n+1}-a_{n}}{b_{n+1}-b_{n}}=L\)
\(\displaystyle \lim_{n\to\infty}\frac{a_{n}}{b_{n}}=L\)
For the proof of the first statement you are using the second statement which is what we want to prove.
No, I am using the first statement to prove the second. I am using the fact that:
exists and is equal to $L$ to assert that:
Ahhh...my apologies for being so thick this morning...
I now (finally) see what you are saying...in my statement:
\(\displaystyle \lim_{n\to\infty}\frac{x^n}{n!}=\lim_{n\to\infty}\frac{x^{n+1}-x^n}{(n+1)!-n!}=\lim_{n\to\infty}\left(\frac{x^n}{n!}\cdot\frac{x-1}{n}\right)={\color{red}\left(\lim_{n\to\infty}\frac{x^n}{n!}\right)}\cdot0=0\)
I am in fact assuming the part in red exists.
Another attempt:
This is in fact very similar to Euge's method...
Let:
\(\displaystyle S=\sum_{k=1}^{\infty}\left(a_k\right)=\sum_{k=1}^{\infty}\left(\frac{x^k}{k!}\right)\)
To determine if $S$ converges, and thus if the terms tend to zero, we may use the ratio test:
\(\displaystyle L=\lim_{k\to\infty}\left|\frac{a_{k+1}}{a_{k}}\right|=\lim_{k\to\infty}\left|\frac{x^{k+1}}{(k+1)!}\cdot\frac{k!}{x^k}\right|=\lim_{k\to\infty}\left|\frac{x}{k+1}\right|=0\)
Since $L=0$, the series converges, and this implies:
\(\displaystyle \lim_{n\to\infty}\frac{x^n}{n!}=0\)
Thanks to everyone that participated! I never knew there would be so many methods to solve this problem. :D My solution is in fact the same as Euge and Mark's, as it arose during my series and sequence homework.
FAQ: What is the limit of x^n/n as n approaches infinity?
What is the concept of "Limit x^n/n"?
The concept of "Limit x^n/n" is a mathematical calculation that involves finding the limit of a function as x approaches infinity. The function is in the form of x raised to a power (n) divided by the same power (n). This limit can help determine the behavior of a function as it approaches infinity.
How is the limit of "x^n/n" calculated?
The limit of "x^n/n" is calculated by taking the ratio between the highest power of x in the numerator and denominator. If the highest power is the same, then the limit is equal to the coefficient of the highest power. If the denominator has a higher power, then the limit is equal to zero. And if the numerator has a higher power, then the limit does not exist.
What is the significance of "Limit x^n/n" in mathematics?
The significance of "Limit x^n/n" in mathematics is that it helps determine the end behavior of a function. It can also be used to evaluate indeterminate forms and solve problems involving rates of change and optimization.
What are the different types of limits for "x^n/n"?
There are three types of limits for "x^n/n": horizontal, vertical, and oblique. A horizontal limit occurs when the limit is a constant value. A vertical limit occurs when the limit is infinite. And an oblique limit occurs when the limit is a linear function.
How can "Limit x^n/n" be applied in real-life situations?
"Limit x^n/n" can be applied in real-life situations to calculate the growth or decay of a population, determine the maximum or minimum value of a function, or analyze the behavior of a physical system as it approaches infinity. It can also be used in economics to calculate the marginal cost and revenue of a business.
