What is the longest pipe that can be carried around a right-angled turn in a hallway?
  • MHB
  • Thread starter Chris L T521
In summary, the purpose of determining the longest pipe that can be carried around a right-angled turn in a hallway is to understand the limitations of physical space. The calculation involves measuring the dimensions of the hallway and the pipe, as well as considering any obstructions or obstacles. Factors such as the width of the hallway, the angle of the turn, the flexibility of the pipe, and the strength and maneuverability of the person carrying the pipe can all affect the maximum length that can be carried. While there may be some general guidelines, there is no specific formula or rule for determining the longest pipe. This information can be useful for planning and logistics purposes, such as moving large objects through narrow or confined spaces in a safe and efficient manner.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: A steel pipe is being carried down a hallway 9 ft wide. At the end of the hallway there is a right-angled turn into a narrower hallway 6 ft wide. What is the length of the longest pipe that can be carried horizontally around the corner?
This week's problem was correctly answered by MarkFL and TheBigBadBen.
Here's MarkFL's solution (which uses Lagrange multipliers):
If we ignore all dimensions of the pipe except the length, this is equivalent to minimizing the sum of the squares of the intercepts of a line passing through the point $(r,s)$ in the first quadrant. Let $a$ and $b$ be the $x$-intercept and $y$-intercept respectively. Thus, the function we wish to minimize is (the objective function):
$f(a,b)=a^2+b^2$
Now, using the two-intercept form for a line, we find we must have (the constraint):
$\displaystyle \frac{r}{a}+\frac{s}{b}=1$
Using Lagrange multipliers, we find:
$\displaystyle 2a=\lambda\left(-\frac{r}{a^2} \right)$
$\displaystyle 2b=\lambda\left(-\frac{s}{b^2} \right)$
and this implies:
$\displaystyle b=a\left(\frac{s}{r} \right)^{\frac{1}{3}}$
Substituting for $b$ into the constraint, there results:
$\displaystyle \frac{r}{a}+\frac{s}{a\left(\frac{s}{r} \right)^{\frac{1}{3}}}=1$
$\displaystyle a=r^{\frac{1}{3}}\left(r^{\frac{2}{3}}+s^{\frac{2}{3}} \right)$
Hence, we have:
$\displaystyle b=s^{\frac{1}{3}}\left(r^{\frac{2}{3}}+s^{\frac{2}{3}} \right)$
and so we find:
$\displaystyle f_{\min}=f\left(r^{\frac{1}{3}}\left(r^{\frac{2}{3}}+s^{\frac{2}{3}} \right),s^{\frac{1}{3}}\left(r^{\frac{2}{3}}+s^{ \frac{2}{3}} \right) \right)=\left(r^{\frac{2}{3}}+s^{\frac{2}{3}} \right)^3$
Now, we need to take the square root of this since the objective function is the square of the distance we actually wish to minimize. Let $\ell$ be the length of the pipe, and we now have:
$\displaystyle \ell_{\max}=\left(r^{\frac{2}{3}}+s^{\frac{2}{3}} \right)^{\frac{3}{2}}$
Letting $r=6\text{ ft}$ and $s=9\text{ ft}$ we have:
$\displaystyle \ell_{\max}=\left(6^{\frac{2}{3}}+9^{\frac{2}{3}} \right)^{\frac{3}{2}}\text{ ft}\approx21.07044713766\text{ ft}$
Here's TheBigBadBen's solution:
I begin with intuitive assumptions:
1: The straight pipe can be made arbitrarily thin
2: An optimal way to manoever the pipe is to keep it flush against the corner of the turn, rotating along the 90 degree bend.
3: The height of the hallway doesn't factor in (i.e. is sufficiently low, I guess).
With that in mind, a pipe can pass through if at all points in this rotation it does not hit the wall.
Long story short, we frame the problem as follows:
"consider a line of the form
(y - 9) + m(x - 6) = 0
for m >= 0. Find the minimum length of the line passing through the first quadrant"
This amounts to a routine minimization problem. We note that for such a line, the axis intersections are given by
(9/m + 6, 0) and (0, 9 + 6m)
The desired length d then satisfies
(9/m+6)^2 + (9 + 6m)^2 = d^2
expanding this, we get
d^2 = 36 m^2 + 108 m + 117 + 108/m + 81/m^2
Now, we find the critical points:
(d/dm)d^2 = 72 m + 108 - 108/m^2 - 162/m^3 = 0
Rejecting the case that m = 0, we multiply by m^3 and factorize to get
18(2m + 3)(2m^3 - 3) = 0
The only root in the desired domain is
m = (3/2)^(1/3)
Plugging in this solution yields the answer
d ~= 21.07
FAQ: What is the longest pipe that can be carried around a right-angled turn in a hallway?
What is the purpose of determining the longest pipe that can be carried around a right-angled turn in a hallway?
The purpose of this question is to understand the limitations of physical space and the maximum size of objects that can be transported through it.
How is the longest pipe that can be carried around a right-angled turn in a hallway calculated?
The calculation involves measuring the dimensions of the hallway and the pipe, as well as considering any obstructions or obstacles that may affect the movement of the pipe.
What factors may affect the maximum length of the pipe that can be carried around a right-angled turn in a hallway?
Is there a specific formula or rule for determining the longest pipe that can be carried around a right-angled turn in a hallway?
While there may be some general guidelines, there is no specific formula or rule as it ultimately depends on the specific dimensions and conditions of the hallway and the pipe being carried.
Why is it important to know the longest pipe that can be carried around a right-angled turn in a hallway?
