What is the magnetic boundary conditions between air and copper?
In summary, we discussed the existence of free current density on the boundary surface of perfect conductors, specifically in copper which is a paramagnetic material. To find the angle of the magnetic field inside a perfect conductor, the magnitude of the current density is needed. However, the quantity of surface current density cannot be determined. It is also true that a static magnetic field can exist inside an ideal conductor, but time-varying fields cannot. The boundary conditions for magnetic fields across an interface can be found in the link provided. The formula for the tangential boundary condition indicates that the current is limited to the surface, but it is possible for current to exist inside the ideal conductor, unlike static charge.
yungman
5,755
292
I understand [itex] \vec J_{free}[/itex] only exist on boundary surface of perfect conductors. Copper is close enough and have surface current. Also copper is paramagnetic material which implies [itex]\mu_{cu} = \mu_0[/itex] or very very close.
In order to find the exact angle of the of the magnetic field inside the perfect conductor like copper, we need to know the magnitude of the current density. My question is how do I find the quantity of the surface current density?
I read somewhere that I cannot find again...that static magnetic field cannot penetrade perfect conductor. Is this true?
Thanks
If by [itex]J_{free}[/itex] you mean current density of free (as opposed to bound) electric charge, that can exist inside an ideal conductor, the only things constrained at the surface of ideal conductors are static charge and time-varying currents.
The boundary conditions for magnetic fields across an interface can be found http://en.wikipedia.org/wiki/Interface_conditions_for_electromagnetic_fields"
A static magnetic field can exist inside an ideal conductor, time varying fields cannot.
dgOnPhys said:
If by [itex]J_{free}[/itex] you mean current density of free (as opposed to bound) electric charge No, it is the free [itex] \vec {J_s}[/itex] , that can exist inside an ideal conductor, the only things constrained at the surface of ideal conductors are static charge and time-varying currents.
Thanks for your reply. I figure that the static mag field can penetrate an ideal conductor. I forgot the formula
[tex] \hat {n_2} X ( \vec {H_2} - \vec {H_1}) = \vec {J_s} [/tex]
But that also bring back to the point that by definition of tangential boundary condition that the current is limited on the surface as the formula indicated. But I can see your point that current don't have to stay on the surface of the ideal conductor as oppose to the charge.
FAQ: What is the magnetic boundary conditions between air and copper?
1. What is a magnetic boundary condition?
A magnetic boundary condition is a physical principle that describes how magnetic fields behave at the interface between two different materials. This principle helps to determine the behavior of magnetic fields in various systems, such as the interface between air and copper.
2. What is the difference between air and copper in terms of their magnetic properties?
Air is considered a non-magnetic material because it does not contain any magnetic elements. On the other hand, copper is a diamagnetic material, which means it produces a weak magnetic field in the opposite direction of an applied magnetic field.
3. How do the magnetic properties of air and copper affect the boundary conditions between them?
The difference in magnetic properties between air and copper leads to a change in the behavior of magnetic fields at their interface. This is because magnetic fields tend to follow the path of least resistance, and the difference in magnetic properties creates a boundary where the magnetic field can change direction.
4. Are there any specific equations or formulas to calculate the magnetic boundary conditions between air and copper?
Yes, there are several equations and formulas that can be used to calculate the magnetic boundary conditions between air and copper. Some of the commonly used equations include the Ampere's Law, the Biot-Savart Law, and the Maxwell's Equations.
5. How do engineers and scientists use knowledge of magnetic boundary conditions between air and copper in practical applications?
Knowledge of magnetic boundary conditions between air and copper is crucial in various practical applications, such as designing electromagnetic devices, magnetic sensors, and magnetic shielding. Engineers and scientists also use this knowledge to improve the efficiency and performance of electric motors and generators.
