What is the magnitude of the current density across A1 ?
The discussion focuses on calculating the current density across a circular conductor with a current of 5.00 A and a radius of 0.400 cm at cross-section A1. The formula used is J = I/A, resulting in a current density of approximately 99,472.8 A/m². A participant points out that the calculation is correct, but the units should be expressed as A/m² instead of A m². Additionally, the problem poses a question about the radius at A2, where the current density is one-fourth that of A1. The conversation emphasizes the importance of correct unit representation in calculations.
zooropa
The figure represents a section of a circular conductor of nonuniform diameter carrying a current of 5.00 A. The radius of cross-section A1 is 0.400 cm.
[URL=http://img97.imageshack.us/i/img01mn.jpg/][PLAIN]http://img97.imageshack.us/img97/7220/img01mn.th.jpg[/URL][/PLAIN]
(a) What is the magnitude of the current density across A1 ?
(b) If the current density across A2 is one-fourth the value across A1, what is the radius of the conductor
at A2 ?
J=I/A= 5.00A/pi(.004)^2=99,472.8 A m^2
Could someone help please? I am doing this the right way?
at A2 ?
Looks correct so far, except for the units of your answer -- should be A/m^2. You did the right thing in the division, just left out the "/" in the final answer's units.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
