What is the magnitude of the spring force given M,K and X
In summary, the magnitude of the spring force acting on the disk in the game is 1380 N and the magnitude of the spring force acting on the toy is 170 N. This is calculated using the equation f = -kx, where f is the spring force, k is the spring constant, and x is the distance the spring is compressed.
AStupidHippo
1.In a game a .12kg disk is shot across a frictionless surface . The spring is compressed by 6cm. The spring constant is 230 N/m. What is the magnitude of the spring force?
2. A piece of plastic is attached to a spring. The spring is compressed 2cm and the released. If the spring constant is 85 N/m, what is the magnitude of the spring force acting on the toy?
f=-kx[/B]
[/B]
1. -230*-6
= 1380
2= -85*-2
=170
You are just being careless. You are told that the spring constant is 85 Newtons per meter and that the spring is compressed 6 centimeters, NOT 6 meters!
Yes, that is quite careless of me. My formulas for both are correct tho, right?
FAQ: What is the magnitude of the spring force given M,K and X
What is the formula for calculating the magnitude of the spring force given mass, spring constant, and displacement?
The formula for calculating the magnitude of the spring force is F = -kx, where F is the magnitude of the spring force, k is the spring constant, and x is the displacement of the spring.
How does the mass affect the magnitude of the spring force?
The mass does not directly affect the magnitude of the spring force. The magnitude of the spring force is only affected by the spring constant and the displacement of the spring.
What is the unit of measurement for the spring constant?
The unit of measurement for the spring constant is Newtons per meter (N/m).
Can the displacement be negative when calculating the magnitude of the spring force?
Yes, the displacement can be negative. The negative sign in the formula for spring force indicates that the force acts in the opposite direction of the displacement.
How does the spring constant affect the magnitude of the spring force?
The spring constant directly affects the magnitude of the spring force. A higher spring constant means that the spring is stiffer and will exert a greater force for a given displacement, whereas a lower spring constant means that the spring is more flexible and will exert a smaller force for the same displacement.
