- #36
Stella.Physics
- 63
- 13
lets say we have three observers, a) one in moving around a static (Schwarzschild) black hole at a radius let's say r=10M b) one that is at infinity and gets light signals from the first observer and c) an observer that is somehow standing still at radius r=10M and also sees the light signals from the first observer.Phil Lawless said:It is possible to extrapolate some classical behaviors into the boundary of a black hole. In the case of supermassive black holes, the event horizon is so far from the center of mass that the gradient of the gravitational field is relatively small, A human astronaut could cross that boundary without being aware of the difference of gravitational attraction between his head and his feet. Near a much smaller black hole, the tidal effects could pull him apart. The same processes would hold for smaller objects, even down to the size of atoms. Eventually, the gradient approaching the singularity would pull everything apart. The question remains: how long does an astronaut have until that happens? With his speed of approach to the singularity increasing all the time, it should be expected that his perception of time, relative to an outside observer, should be decreasing. The details may be impossible to work out with confidence, but he could quite possibly spend a subjective eternity approaching the singularity. This is essentially the premise of Tipler's book, The Physics of Immortality.
Now for the first observer if we say that ##\theta=\pi /2## at a certain level and also his r is fixed we get
##-d\tau^2=ds^2 = - \bigg(1- \frac{2M}{r} \bigg) dt^2 + r^2 d\phi^2## from the metric element
and that would be ##\Delta\tau=20\sqrt{7}\pi M##
for the second observer the time that he would get between those signals are ##\Delta t=20\sqrt{10} \pi M##
and the third and static observer the proper time between those signals would be ##\Delta \tau' = 20\sqrt{8}\pi M##
So we get ##\Delta \tau < \Delta \tau' < \Delta t ## because for the observer far away measuring time t, the static observer feels only the gravitational expansion of time whereas the one going around the black hole feels both the gravitational (GR) and the kinetic (SR) contraction of time.
I've left out many math steps but that would give you an idea although this case is different .
Another thing is while approaching the black hole and for r<2GM time t from timelike becomes spacelike. so when you are traveling towards a Black Hole from a point and on it's like moving forward in time, like going to the future, yes I say what happens when you travel in space by say what will happen from the time point of view.
"Thus you can no more stop moving toward the singularity than you can stop getting older. Since proper time is maximized along a geodesic, you will live the longest if you don't struggle. As you fall to the singularity your feet and head will be pulled apart from each other while your torso is squeezed to infinitesimal thinness" as detailed in the book "Gravitation" by Misner, Thorne and Wheeler.
