MHB What is the maximum and minimum sum for $|a-b|+|b-c|+|c-a|$ with given relation?
  • Thread starter Thread starter lfdahl
    Maximum Minimum
The discussion focuses on determining the maximum and minimum values of the expression |a-b| + |b-c| + |c-a| under the constraint (a-b)³ + (b-c)³ + (c-a)³ = 60. Participants explore various integer combinations of a, b, and c to satisfy the cubic equation while calculating the corresponding sums. The minimum sum is found to be 12, occurring when the integers are spaced evenly. The maximum sum is identified as 36, achieved with specific values of a, b, and c that maximize the absolute differences. The analysis highlights the relationship between the cubic constraint and the resulting sums.
lfdahl
MHB
Find the maximum and minimum of the sum $|a-b|+|b-c|+|c-a|$, if the integer numbers $a,b$ and $c$ satisfy the following relation:
\[ (a-b)^3+(b-c)^3+(c-a)^3 = 60 \]
Mathematics news on Phys.org
using $x + y +z = 0 => x^3+y^3 + z^3 = 3xyz$ we get letting x = a-b , y = b-c , z = c - a = -(x+y)
$3(a-b)(b-c)(c-a) = 60$ or $(a-b)(b-c)(c-a) = 20$
or $xy(x+y) = - 20$
taking factors of -20 (product of 3 numbes) such that product is 20 we get 3 triplets ( -1,-4,-5), (-1,5,4), (-4,5,1) and in all
cases $|x| + |y| + |z|$ or $|a-b| + |b-c| + |c-a| = 10$
Needless to say that both maximum and minimum are 10
or $xy(x+y) = - 20$
Later I realized that there is only one solution (a-b=5, b-c = -4, c-a = -1) or a permutation of the same permutation counting the same
Well done!
Yes, the only solution is the set $(5,-4,-1)$ and its permutations.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
