What is the maximum distance that parallax error can be used?
In summary, the maximum distance at which parallax error can be effectively used typically ranges from a few meters to several kilometers, depending on the precision of the instruments and the specific observational context. Beyond this range, the angular displacement becomes too small to measure accurately, leading to significant errors in distance estimation.
Dc2LightTech
23
TL;DR Summary
measuring astronomical distanced
using the Earths orbit, what is the maximum distance that can be measured using parallax error?
Likes OmCheeto
Astronomy news on Phys.org
Dc2LightTech said:
TL;DR Summary: measuring astronomical distanced
What accuracy/precision?
Likes Vanadium 50
As @Bystander implies, there is no maximum distance. It depends on the accuracy of the position measurements.
How high is up?
Likes Bystander
Before putting too much effort into decrypting the question, one might want to take a peek at the OP's prior threads.
Likes berkeman
using the orbit around the sun, with current technology, how far can the best optical telescopes detect and parallax shift of a star using a distant galaxy as a reference for infinity.
Now you have a good question. What research have you done? What have you found so far?
And when you answer, please include whether you are talking earth or space based.
Likes phinds
It isn't as simple as resolution, by the way. If you have a diffraction-limited telescope, the Rayleigh criterion will give you the ballpark for the angular separation needed to see two distinct points rather than one, and that's roughly what you need here - you need to be able to compare two images and say "yup, that point is in a different place". The figure comes out in radians. Convert to arcseconds, and one upon that is the number of parsecs you can use the method to.
Note that ground based telescopes may not be diffraction limited due to atmospheric conditions.
Also, as you noted that you need a background object to treat as a fixed point. So you need to have a reasonably large field of view to include an appropriate object or two, so you can be certain you've correctly matched your images. That's not always possible with a really high resolution telescope, so you may be forced to use a wider field telescope, or just observe something else.
Try Googling the Gaia mission from ESA. The data from Gaia is the current state of the art for astrometric accuracy.
Likes OmCheeto
I suspect they usually aren't.
Further, one could probably do better with ground base by extended observation. But while some stars might be valuable to do this with, why would you spend the obserrving time to do this with every satr? Delta Cephei makes a lot of sense. 9 Cephei, not so much.
if knew the pixel/angular resolution of the best sensor. and the typical Pixel/cross section for a faint star then calculation is not a hard thing to do. should be easy in LabView. I did a orbital flight dynamics program in Labview for fun. Moon landing from unlocking in orbit to touchdown. this should be easy. might be easy to simulate it.
I figure using the light time for the earths orbit as a leg, draw a triangle with the angle based on the resolution and calculate the distance to intercept. distance is in light time
And that gives no answer at all to your question. Have you actually researched your question? That is, not HOW do you do it, but what is the answer? That was your original question.
Changing questions after people have tried to answer your original question is considered bad form.
Likes Bystander
Of course he did. He told us to find the answer for him! :smile:
You could certainly build a CCD with 50 nm pitch, and maybe even 5 nm, although I have no idea how you would power it up without it bursting into flames - each square cm would have 4 trillion channels.
But such a unit is not just smaller than what is normally used, it's smaller than a light wave. It would tell you nothing a more realistic unit with a larger pitch wouldn't.
We've spent a day trying to figure out exactly what you want to know. We still don't. Why don't you look up a bunch of stars in Wikipedia, see what their parallaxes and uncertainties are, and use that to calculate whatever number you are interested in?
Likes phinds
It's not as simple as knowing the pixel resolution. Gaia is able to get angular accuracy much, much smaller than 1 pixel. It's worth looking up how they do that.
