What is the maximum height h of his jump above the end of the ramp
In summary, a 48 kg skier with an initial height of 28 m and a velocity angled at 28° above the horizontal starts on a frictionless ski-jump ramp. To determine the time at which the skier reaches maximum height before descending, the velocity should be broken down into vertical and horizontal components and the equations of motion, potential and kinetic energy should be applied.
nmegabyte
A 48 kg skier starts from rest at a height of H = 28 m above the end of the ski-jump ramp. As the skier leaves the ramp, his velocity makes an angle of 28° with the horizontal. Neglect the effects of air resistance and assume the ramp is frictionless.
Could u give me a formula i need to start with because i have no idea about the formula.
Split the velocity into its vertical and horizontal components. Then just calculate how long until the vertical component equals zero, this will be the time equivalent to the maximum height before the skier starts to descend again. You should have learned the equations of motion, and the equations for potential and kinetic energy, that's about all you'll need.
Related to What is the maximum height h of his jump above the end of the ramp
1) What is the maximum height h of his jump?
The maximum height h of his jump is the highest point that the person reaches during their jump above the end of the ramp.
2) How is the maximum height h of his jump calculated?
The maximum height h of his jump is calculated by measuring the vertical distance from the top of the person's head to the end of the ramp.
3) Can the maximum height h of his jump vary?
Yes, the maximum height h of his jump can vary depending on factors such as the person's speed, angle of the ramp, and their jumping ability.
4) What is the significance of knowing the maximum height h of his jump?
Knowing the maximum height h of his jump can help us understand the person's jumping ability and can be used in sports and physics to analyze the mechanics of the jump.
5) How can the maximum height h of his jump be increased?
The maximum height h of his jump can be increased by improving the person's strength, technique, and speed. It can also be increased by adjusting the angle of the ramp or using a higher ramp.
