What is the maximum length of the spring?
The discussion centers on determining the maximum length of a spring while considering gravitational effects and energy conservation. The initial formula proposed involves spring potential energy and kinetic energy but lacks clarity on its application. Participants emphasize the need to incorporate gravitational potential energy along with kinetic and spring potential energy in calculations. A more comprehensive approach is suggested to accurately assess the spring's behavior under these conditions. Overall, understanding the interplay of these energy types is crucial for solving the problem effectively.
annnnnw
New member has been reminded to always show lots of work in their schoolwork thereads.
A mass of 0.4 kg hangs motionless from a vertical spring whose length is 0.95 m and whose unstretched length is 0.65 m. Next, the mass is pulled down to where the spring has a length of 1.20 m and given an initial speed upwards of 1.6 m/s. What is the maximum length of the spring during the motion that follows?
Spring Stiffness F=kx
Conservation of energy
I know gravity needs to be taken into account and that I can find the stiffness but generally I'm pretty lost
Any conservation laws that you can apply?
I tried
1/2(k_s)(s_f)^2 = 1/2(m)(v_i)^2 + 1/2(k_s)(s_i)^2
But I'm not really sure it's the best for what going on here
Thread paused for Moderation...
annnnnw said:
I tried
Thread is reopened provisionally.
@annnnnw -- Please show more effort in your replies in this thread. There are several types of energy involved in this question, including gravitational potential energy (GPE), kinetic energy (KE) and the spring's potential energy (PE) based on how extended it is from its resting postion. Please include all of these in your calculations. Thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
