What is the maximum load the concrete can support?
In summary, a circular pillar of concrete with a radius of .6 m can support a maximum load of 3.1 MN/m^2, regardless of the load direction.
Dennydont
45
A certain type of concrete has a tensile breaking stress of 3.1 MN/m^2, a compressive breaking stress of 37.7 MN/m^2 and a shear breaking stress of 9.4 MN/m^2. A circular pillar of this concrete has a radius of 0.6 m. What is the maximum load it can support assuming that it is evenly distributed over the top of the pillar?
Normal stress, [PLAIN]http://upload.wikimedia.org/math/9/d/4/9d43cb8bbcb702e9d5943de477f099e2.png=F/A
Shear stress, [PLAIN]http://upload.wikimedia.org/math/d/9/5/d95fd1519e587418ebe3da8fb081701f.png=F/A
I haven't dealt with this sort of problem where the object has more than one type of stress applied to it. I tried finding the maximum load (or force) by adding up all the stresses and multiplying by the area which in this case is πr^2 but this doesn't give me the correct answer. I'm running out of ideas, could Pythagoras' theorem be considered? Please help!
You added a tension stress to a compression stress? is the pillar going to be compressed, or will it be stretched, if it is supporting some "load"?
Is the load above it, below it, or beside it?
Which of those stresses would apply to an upright pillar supporting a load from above?
Ah of course, how silly of me! Even though there are multiple stresses in the problem, only one is required for solving. Thank you!
Well, for completeness you need to check two not just one. The "compressive breaking stress" is just another way of referring to the normal stress that will break the pillar. But this limit is bigger than the other limit. So the check for this one is that it's stronger than the other. So if the other one is ok this one is too. And if the other one fails this one does not matter.
But it tells you that you can predict the method of failure of the pillar as you increase the load to the point it does fail.
Related to What is the maximum load the concrete can support?
1. What is the maximum load the concrete can support?
The maximum load that concrete can support depends on various factors such as the type of concrete, its age, and the specific conditions of the structure it is supporting. Generally, concrete has a maximum load capacity of 3,000-5,000 pounds per square inch (psi).
2. How do you determine the maximum load capacity of concrete?
The maximum load capacity of concrete is determined through a series of tests and calculations, taking into account factors such as the compressive strength, tensile strength, and other properties of the concrete. These tests are usually conducted by structural engineers.
3. Can the maximum load capacity of concrete be increased?
Yes, the maximum load capacity of concrete can be increased by using reinforcement materials such as steel bars or fibers, or by adding chemical admixtures that improve its strength and durability. However, the maximum load capacity should always be determined and approved by a structural engineer.
4. What happens if the maximum load capacity of concrete is exceeded?
If the maximum load capacity of concrete is exceeded, it can result in structural failure, which can be dangerous and costly. Cracks, deformations, and collapse of the structure can occur, depending on the severity of the overload. It is important to always adhere to the recommended maximum load capacity to ensure the safety and stability of the structure.
5. Are there any safety precautions to consider when working with concrete and its maximum load capacity?
Yes, there are several safety precautions to consider when working with concrete and its maximum load capacity. These include following proper construction techniques, adhering to recommended load capacity limits, using reinforcement materials when necessary, and regularly inspecting and maintaining the structure. It is also important to consult with a structural engineer to ensure the safety and stability of the structure.
11K
14K
16K
  • Mechanical Engineering
