MHB What is the maximum of the given function in the closed square $D$?
The function f(x1, x2) = x1 + x2 achieves its maximum value of 2 within the closed square D defined by the vertices (0,0), (1,0), (1,1), and (0,1). This maximum occurs at the point (1,1), where both x1 and x2 are at their upper limits. The discussion emphasizes that since all other feasible values of the function are less than 2, (1,1) is confirmed as the optimal solution. It is noted that for linear programming problems, only corner points need to be evaluated to find the maximum. Thus, the maximum of the function is conclusively established as 2 at the point (1,1).
evinda
MHB
Hello! (Wave)
We consider the function $f(x_1,x_2)=x_1+x_2$ and the (closed) square $D$ with edges $(0,0), (1,0), (1,1), (0,1)$.
Check if $f$ has a maximum in $D$ and if so, find the points of $D$ at which this maximum is achieved.$$\max_{(x_1,x_2) \in D} (x_1+x_2)$$
$$(S)\left\{\begin{matrix}
x_1 \geq 0\\
x_2 \geq 0\\
x_1 \leq 1\\
x_2 \leq 1
\end{matrix}\right.$$
so $D=\{ (x_1, x_2) \in \mathbb{R}^2: x_1, x_2 \text{ satisfy } (S)\}$.
$$x_1, x_2 \geq 0$$
Obviously $\max_{(x_1, x_2) \in D} (x_1+x_2) \leq \max_{(x_1, x_2) \in D} x_1 + \max_{(x_1, x_2) \in D} x_2 \leq 1+1=2 $
and $\max_{(x_1, x_2) \in D} (x_1+x_2)=f(1,1)$, so $(1,1)$ is the optimal solution of the linear programming problem.
How do we deduce that the maximum of the given function is $2$. Because of the fact that the maximum is less or equal to $2$ and there is a point $(1,1)$ for which the value $2$ is achieved?
Mathematics news on Phys.org
evinda said:
Hello! (Wave)
Small correction: it's "an" optimal solution.
We don't know yet if it is "the" optimal solution. (Nerd)
Yes. (Smile)
Still, I believe the question asks for "all" points... (Sweating)
Why? Aren't all the other values that $f$ could get smaller? Or am I wrong? (Thinking)
I like Serena said:
Yes. (Smile)
So in order to show that we have one optimal solution do we have to reject the other feasible solutions?
Indeed. And that's exactly the point.
Because all other values that $f$ could get are smaller, it is "the" maximum. (Happy)
Moveover, if the boundary were not included, there would be no maximum, only a supremum. (Nerd)
In order to reject the other feasible solutions do we have to compute the values $f(0,0), f(1,0), f(0,1)$ and the value of $f\left( \frac{1}{m}, \frac{1}{n}\right), n,m \in \mathbb{N}$ ? (Thinking)
From a linear programming point of view, indeed we need to check all the corner points.
But that only works if the function to maximize is a linear function.
Where do your $f\left( \frac{1}{m}, \frac{1}{n}\right)$ come from? (Wondering)
More generally, we would take the partial derivatives and see where they are zero.
Additionally, we would inspect the boundaries to see if there is a maximum there.
For linear programming problems that can be simplified to just looking at the corner points. (Nerd)
Ah I didn't know that if we have a linear programming problem we look only at the corner points. (Whew)
So we say that $\max_{(x_1, x_2) \in D} (x_1+x_2) \leq 2$ and
$$f(0,0)=0 \\ f(1,0)=1 \\ f(1,1)=2 \\ f(0,1)=1$$
thus the maximum of the function $f$ is $2$ and is achieved for $(x_1, x_2)=(1,1)$, right?
Yep! (Happy)
I like Serena said:
Yep! (Happy)
Nice... Thank you! (Smile)
