What is the Maximum Temperature for a Copper Block at 1000 atm Pressure?
In summary, the problem involves a block of copper at a pressure of 1 atm and a temperature of 5 °C, which is then raised to 10 °C at constant volume. The final pressure is found to be 40200 Pa using the formula (Pf-Pi)=(volume expansivity / isothermal compressibility) (Tf-Ti). For part (b), the highest temperature that the system can be raised to is 17 °C, despite getting a temperature of 2.4 °C for a pressure of 1000 atm.
Muthumanimaran
81
(a) A block of copper at a pressure of 1 atm and a temperature of 5 degree celcuis is kept at constant volume. If the temperature is raised to 10 degree celcius what will be the final pressure?
(b) If the vessel holding the block of copper has a negligibly small thermal expansivity and can withstand a maximum pressure of 1000atm, what is the highest temperature to which the system may be raised?
(Note: The volume expansivity and isothermal compressiblity are not always listed in handbooks of data. However, volume expansivity is three times the linear expansion coefficient and isothermal compressibility is reciprocal of the bulk modulus. For this problem, assume that volume expansivity and isothermal compressibility remain practically constant within the temperature range of 0 to 20 degree celcius at the values of 4.95 x 10^(-5) K^-1 and 6.17 x 10^(-12))
part (a) of the problem can be easily done by using by substituting the given data in the formula above.
$$P_{f}-P_{i}=\frac{\beta}{\kappa}(T_{f}-T_{i})$$
$$P_{f}-10^{5}=\frac{4.95 \times 10^{-5}}{6.17 \times 10^{-12}} (10-5)$$
gives Pf=40200 Pa
If I do the same for part (b) by taking initial temperature as 0 degree celcius and initial pressure as 1 atm, the final temperature is 2.4 degree celcius but the correct answer is 17 celcius, give me a hint.
What answer to you get for part (a)? Also, please show your calculations.
gives Pf=40200 Pa
Muthumanimaran said:
Pf=40200 Pa
You are off by a few orders of magnitude.
In any case, your result for Tf = 10 °C is Pf < 1000 atm. How can you get a temperature of 2.4 °C for 1000 atm?
Related to What is the Maximum Temperature for a Copper Block at 1000 atm Pressure?
What is the maximum temperature in a certain area?
The maximum temperature in a certain area refers to the highest recorded temperature within a specific time frame, typically within a day. This can vary depending on factors such as location, season, and climate patterns.
How is the maximum temperature measured?
The maximum temperature is typically measured using a thermometer, which can be either a traditional mercury thermometer or a more modern electronic thermometer. The thermometer is placed in a shaded area and left for a period of time until it reaches thermal equilibrium with its surroundings.
What factors can affect the maximum temperature?
The maximum temperature can be influenced by various factors such as sunlight exposure, humidity, wind, and air pressure. These factors can impact the amount of heat absorbed or reflected by the Earth's surface, ultimately affecting the maximum temperature recorded.
Why is it important to track the maximum temperature?
Tracking the maximum temperature is crucial for understanding weather patterns and predicting future climate changes. It also helps in identifying potential heatwaves, droughts, and other extreme weather events that can have significant impacts on human health and the environment.
How can maximum temperature data be used in scientific research?
Maximum temperature data is used in a wide range of scientific research, including climate studies, agriculture, and environmental monitoring. It can also be used to analyze the effects of urbanization and land use changes on local temperature patterns. Additionally, maximum temperature data can be used to develop more accurate weather forecasting models.
