What is the meaning in the 144 Optical Fiber Cable? Especially why 144
In summary, the standard for 144 fibers in an Optical Fiber Cable is based on the increment of 12 strands, with 144 being the highest number that can be easily accommodated in a single cable. This number is also significant in terms of optimizing space and fitting into circular shapes, as seen with other cable types.
tipu_sultan
During studying the telecom underground cable network I came across the Optical Fiber Cable having the 144 fibers (single mode).
I want to know why 144?
Is this a Some standard to have 144 fibers in one cable?
I have also viewed some of the datasheet having 144 fibers Optical Fiber Cable.
I think it might be like that in a single 144 core fibers we avail SDH, Telecommunications and also some fiber spare for future use.
Fiber optic cables come in 12 strand increments (with some exceptions). Large outside plant cables are built with 12 strands within a "tube" then up to 24 tubes in the cable surrounding a central strength member (among other things).
Fiber patch panels are also designed for increments of 12.
Likes 1 person
19 is another magic number with cables (and 19 is, at first sight, even more random). The geometry of 'circles' allows you to fit 19 round cables into a cylinder, so it's the number of strands commonly in steel cable (for rigging etc) and in copper conductors. (1 in the centre, then layers of 6 and 12).
32 is the next in the series . . . .
FAQ: What is the meaning in the 144 Optical Fiber Cable? Especially why 144
1. What is the significance of the number 144 in the 144 Optical Fiber Cable?
The number 144 in the 144 Optical Fiber Cable refers to the total number of individual optical fibers within the cable. This number was chosen based on the specific needs and requirements of the network or application the cable will be used for.
2. Why is the number 144 commonly used in Optical Fiber Cables?
The number 144 is commonly used in Optical Fiber Cables because it allows for a high number of individual fibers in a single cable, while still being manageable for installation and maintenance purposes. It is also a multiple of 12, which is the standard unit for fiber optic cable count.
3. Is there a reason why 144 is the optimal number for Optical Fiber Cables?
While there is no specific reason why 144 is the optimal number for all Optical Fiber Cables, it is often chosen based on the specific needs and requirements of the network or application. In some cases, other numbers such as 96 or 288 may be used, depending on the desired capacity and configuration of the cable.
4. Does the number of fibers in a 144 Optical Fiber Cable affect its performance?
The number of fibers in a 144 Optical Fiber Cable does not directly affect its performance. However, having more fibers does allow for higher bandwidth and capacity, which can indirectly improve performance for data transmission.
5. Are there any drawbacks to using a 144 Optical Fiber Cable with a high number of fibers?
One potential drawback of using a 144 Optical Fiber Cable with a high number of fibers is that it may be more expensive and require more space for installation. Additionally, having more fibers may also increase the risk of damage or failure, as there are more individual components that could potentially be affected.
17K
