What is the meaning of instantaneous velocity and how is it defined?
In summary, the concept of instantaneous velocity is defined using limits, as the rate of change at a specific moment in time. This can be seen in the example of the car traveling at 2 mph at time t, where the displacement function is used to calculate the limit. The issue of interpreting this limit also arises in the context of differentiation of non-linear functions, where the rate of change at a single point may seem unclear. However, this concept can be understood as the average rate of change between two points 'merging' as the interval length decreases to zero. Ultimately, the concept of instantaneous velocity is a formalization of our intuitive understanding of motion and is defined without any metaphysical mystery.
Poirot1
245
I'm not really sure how this concept makes sense. We give it meaning by way of a limit but, to my mind, at any instant the car is motionless so how can it have a velocity? What, in essence, does it mean to say that at some point in time a car is going 2 mph?
Re: Instanaeous velocity
To define what it means to say that a car is going at the speed of 2mph would again require the use of limits. If $\lim_{h\to 0}\frac{x(t_0+h)-x(t_0)}{h}=2$ then the speed at $t=t_0$ is $2$, where $x(t)$ is the displacement of the car from any given reference at time $t$. But I guess you already knew that. I don't what more can I say.
Can you elaborate on "the car is motionless at every instant"??
Yes you can say mathematically this car is traveling at 2 mph at time t, but I am saying how do we intepret this limit? At time t, the car is stationary so I am confused as to what we are saying when we say this car is traveling at 2 mph.
Can you say something more about the following?
Poirot said:
At time t, the car is stationary...
In fact, the 'issue' generalises to differentiation of non-linear functions. Take f(x)=x^2.
when x=2, the derivative is 2. Now if one is asked to explain what a derivative tells you, then you would probably say along the lines 'the rate of change of y with x'. But what does the rate of change mean at a single point? I hope this helps you to understand.
Would you agree that the 'average rate of change' between $2$ and $4$ of the function $y=x^2$ is $(16-4)/2=6$?
If yes, then what is the average rate between $2$ and $2+h$ for h=1, 0.9, 0.8,...,0.1 ?
Does some pattern emerge? As $h$ gets smaller and smaller, you don't have average rate between two distinct points. The two points 'merge'. Thus the rate of change of y with x at x=2 is the avergae rate of change between 2 and 2.
Of course this is just an intuitive way of looking at it. The real thing is limits. But one should know that the concept of limits is just a formalization of our intuition, just as most of mathematics is.
if you are looking for an explanation of instantaneous velocity, then instantaneous velocity is the velocity at a specific moment. If a car is traveling along a road and had to stop for a red light and such, the motion of car against time will not be linear and therefore will not contain a constant gradient and if you wish to find the gradient of a specific point in a graph where the motion of car is against time, at a specific point then instantaneous velocity comes in handy.
It means exactly what the definition says. The rate of change at a point is the limit of the average rate of change over intervals containing the point as the length of the intervals decrease to zero (with due allowances for end effects which I can't be bothered with here).
If you want to quibble about average rate of change over an interval the answer is just the same, it is defined to be the change in the function value divided by the corresponding change in x (the interval length).
There is no metaphysical mystery here, just a definition.
FAQ: What is the meaning of instantaneous velocity and how is it defined?
What is instantaneous velocity?
Instantaneous velocity is the rate of change of an object's position at a specific moment in time. It is the slope of the object's position-time graph at that particular point.
How is instantaneous velocity different from average velocity?
Average velocity is the total displacement of an object divided by the total time taken. It gives an overall idea of an object's motion. On the other hand, instantaneous velocity is the velocity at a particular instant and can vary throughout an object's motion.
How is instantaneous velocity calculated?
To calculate instantaneous velocity, we use the formula v = Δx/Δt, where v is the velocity, Δx is the change in position, and Δt is the change in time. We can also use the derivative of the position function with respect to time to calculate instantaneous velocity.
Can instantaneous velocity be negative?
Yes, instantaneous velocity can be positive, zero, or negative, depending on the direction of an object's motion. For example, if an object is moving in the positive direction, its instantaneous velocity will be positive, and if it is moving in the negative direction, its instantaneous velocity will be negative.
Why is instantaneous velocity important in physics?
Instantaneous velocity is crucial in physics because it helps us understand the motion of an object at a particular moment. It allows us to analyze an object's acceleration, direction of motion, and position at a specific time. It also helps in determining the forces acting on an object and predicting its future motion.
