What is the Minimum of f(x) Without Using Calculus?
  • MHB
  • Thread starter anemone
  • Tags
    Minimum
In summary, kaliprasad's solution is inefficient because he didn't need to use the calculus to determine the minimum.
anemone
MHB
POTW Director
3,883
115
Without using the calculus, determine the minimum of $f(x)=(x^2-6)(x^2-8)(x^2-10)(x^2-12)+(6\cdot 8\cdot 10\cdot 12)$.
Mathematics news on Phys.org
given expression = $(x^2-6)(x^2-12)(x^2-8)(x^2-10) + 6\cdot 8 \cdot 10\cdot 12 $
=$(x^4-18x^2 + 72)(x^4-18x^2 + 80) +6\cdot 8 \cdot 10\cdot 12 $
=$((x^2-9)^2 - 9) ((x^2-9)^2 - 1) +6\cdot 8 \cdot 10\cdot 12 $
the 2nd term is constant and the 1st term is product of 2 terms
for $(x^2-9)$ less than 1 or greater than 9 both terms are positive
for it between 1 and 9 one term is positive and another is -ve and is lowest when $x^2-9$ in the middle that is 5 and lowest value becomes 5744
Thanks for participating in this challenge, kaliprasad!
My solution, which the method used is more or less the same as yours:
Let $y=x^2-9$, the original equation becomes
$\begin{align*}f(y)&=(y+3)(y+1)(y-1)(y-3)+6\cdot 8\cdot 10\cdot 12\\&=(y^2-9)(y^2-1)+6\cdot 8\cdot 10\cdot 12\\&=y^4-10y^2+9+6\cdot 8\cdot 10\cdot 12\\&=(y^2-5)^2+(6\cdot 8\cdot 10\cdot 12-16)\end{align*}$
Now, there are two ways to find the minimum of $f(x)$:
1. We can actually conclude, at this point the the minimum of $f(x)=6\cdot 8\cdot 10\cdot 12-16=5744$.
2. We can conclude first up to this point that the minimum of $f(y)$ occurs at $y^2=5,\,\rightarrow y=\pm \sqrt{5}$ and substituting this back to $f(x)$ to get the minimum of the function of $f(x)$, we get
$\begin{align*}f(x)_{\text{minimum}}&=(\pm\sqrt{5}-9+6)(\pm\sqrt{5}-9+8)(\pm\sqrt{5}-9+10)(\pm\sqrt{5}-9+12)+6\cdot 8\cdot 10\cdot 12\\&=(\pm\sqrt{5}-3)(\pm\sqrt{5}+3)(\pm\sqrt{5}-1)(\pm\sqrt{5}+1)+6\cdot 8\cdot 10\cdot 12\\&=(5-9)(5-1)+6\cdot 8\cdot 10\cdot 12\\&=-16+5760\\&=5744\end{align*}$
$\begin{align*}f(y)&=(y+3)(y+1)(y-1)(y-3)+6\cdot 8\cdot 10\cdot 12\\&=(y^2-9)(y^2-1)+6\cdot 8\cdot 10\cdot 12\\&=y^4-10y^2+10+6\cdot 8\cdot 10\cdot 12\\&=(y^2-5)^2+(6\cdot 8\cdot 10\cdot 12-25)\end{align*}$
so much calculation is not required as putting $y^2-5 = 0 $ we get the result directly
kaliprasad said:
so much calculation is not required as putting $y^2-5 = 0 $ we get the result directly.
Yes, that was inefficient of me not to observe more because if I did, I would save some extra tedious work to figure out the minimum of $f$, and I could really just deduce it, just like you did. (Nerd)
the f(y) should be
kaliprasad said:
the f(y) should be
Oh My...it seems I misunderstood of what you told me (implicitly) yesterday and that my typo led me to think I have to substitute the $y$ value back to get the minimum of $f(x)$...
I will fix the error now, thanks for your patient to make me realized what did I miss in this case.:eek:
FAQ: What is the Minimum of f(x) Without Using Calculus?
What is the purpose of finding the minimum of a function?
Finding the minimum of a function is important in many fields of science and engineering, as it helps us understand the behavior and properties of a system or process. It also allows us to optimize and make improvements to the system.
How is the minimum of a function typically found?
The minimum of a function is typically found using mathematical methods such as calculus or optimization algorithms. These methods involve finding the critical points of the function and evaluating them to determine the minimum value.
What is a local minimum?
A local minimum is a point on a function where the value of the function is smaller than all the values of the function in its immediate vicinity. It is not necessarily the global minimum of the function, but it is the smallest value in a specific region.
Can a function have more than one minimum?
Yes, a function can have multiple local minima, as well as a global minimum. This is dependent on the shape and behavior of the function. For example, a function with a valley-like shape may have multiple local minima.
How does the number of variables in a function affect finding the minimum?
The number of variables in a function can greatly affect the complexity of finding the minimum. In general, the more variables there are, the more difficult it is to find the minimum. This often requires more advanced mathematical techniques and may result in multiple minimum points.
