What is the minimum perimeter of a triangle with given vertices?
  • MHB
  • Thread starter Ackbach
  • Tags
    2016
In summary, a triangle is a polygon with three sides and three angles, and its perimeter is the total length of all its sides. To find the minimum perimeter of a triangle with given vertices, the shortest distance between the vertices must be found using the distance formula or by drawing a line and measuring its length. A triangle cannot have a negative perimeter, and there is no specific formula for finding the minimum perimeter with given vertices, but the distance formula can be used to calculate the shortest distance between any two points.
Ackbach
MHB
4,155
93
Here is this week's POTW:
Given a point $(a,b)$ with $0<b<a$, determine the minimum perimeter of a triangle with one vertex at $(a,b)$, one on the $x$-axis, and one on the line $y=x$. You may assume that a triangle of minimum perimeter exists.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Re: Problem Of The Week # 245 - Dec 19, 2016
This was Problem B-2 in the 1998 William Lowell Putnam Mathematical Competition.
Congratulations to Opalg and IanCg for their correct solutions. Here is Opalg's solution: $+1$ for cool TikZ picture.
[TIKZ]\coordinate (X) at (5,1.5) ;\coordinate [label=left: $A$] (A) at (2,2) ;\coordinate [label=below left: $B$] (B) at (3.25,0) ;\draw (-0.5,0) -- (5.5,0) ;\draw (0,-1.5) -- (0,5.5) ;\draw (0,0) -- (5,5) ;\draw (B) -- (X) -- (1.5,5) -- (A) -- (B) -- (5,-1.5) -- (X) -- (A) ;\draw (6,1.5) node {$P = (a,b)$} ;\draw (6.25,-1.5) node {$Y = (a,-b)$} ;\draw (2,5.25) node {$X = (b,a)$} ;\draw [blue,dashed] (1.5,5) -- (5,-1.5) ;\draw [red] (X) -- (2.725,2.725) -- (4.2,0) -- cycle ;[/TIKZ]​
Let $P = (a,b)$ be the given point. Let $X = (b,a)$ be the reflection of $P$ in the line $y=x$, and let $Y = (a,-b)$ be the reflection of $P$ in the $x$-axis. Let $A$ be a point on $y=x$ and let $B$ be a point on the $x$-axis.
The triangles $PAX$ and $PBY$ are isosceles, so that $PA = AX$ and $PB = BY$. Therefore the perimeter of the triangle $PAB$ is the sum of the lengths $XA$, $AB$, $BY$. This is obviously minimised when $XABY$ is a straight line.
So move $A$ and $B$ to the points on their respective lines where these lines intersect the line $XY$. The corresponding triangle (shown in red in the diagram) will be the one with minimal perimeter. This perimeter is the distance $d$ from $X$ to $Y$, given by $d^2 = (b-a)^2 + (a+b)^2 = 2(a^2 + b^2)$.
Conclusion: the minimal perimeter is $\sqrt{2(a^2+b^2)}$.
FAQ: What is the minimum perimeter of a triangle with given vertices?
What is a triangle?
A triangle is a polygon with three sides and three angles. It is one of the basic shapes in geometry and can be classified as equilateral, isosceles, or scalene based on the lengths of its sides.
What is the perimeter of a triangle?
The perimeter of a triangle is the total length of all its sides. It is calculated by adding the lengths of the three sides together.
How do you find the minimum perimeter of a triangle with given vertices?
To find the minimum perimeter of a triangle with given vertices, we need to find the shortest distance between the vertices. This can be done by using the distance formula or by drawing a line between the vertices and measuring its length.
Can a triangle have a negative perimeter?
No, a triangle cannot have a negative perimeter. Perimeter is a measure of distance and cannot be negative. If the lengths of the sides are negative, it would simply be interpreted as the length in the opposite direction.
Is there a specific formula for finding the minimum perimeter of a triangle with given vertices?
No, there is no specific formula for finding the minimum perimeter of a triangle with given vertices. It depends on the specific vertices and their positions relative to each other. However, the distance formula can be used to calculate the shortest distance between any two points, which can then be used to find the minimum perimeter of the triangle.
