MHB What is the minimum value for x in this triangle with angle bisectors AD and BD?
The minimum integer value for x in the triangle with angle bisectors AD and BD is determined to be 16. Attempts to reduce x to 15 lead to a scenario where the triangle ceases to exist, as the angles would sum to 180 degrees, making AC parallel to BC. The reasoning involves fixing points B and D while rotating line AD, which demonstrates that reducing x further results in a non-triangular configuration. Thus, the conclusion is that x cannot be less than 16. The discussion emphasizes the geometric implications of angle bisectors in determining the minimum value.
ketanco
Hello,
In the attached, what is the minimum integer value x can take?
AD and BD are angle bisectors
the answer is 16 - but i do not know how they did it
I am totally stuck, could not think of anything here. The angle bisector formula I know does not fit hereView attachment 8569
Mathematics news on Phys.org
Here is an intuitive idea of what this question is about. It's up to you to express it mathematically!
Suppose we keep $B$ and $D$ fixed, and imagine what happens as we try to reduce $x$ by rotating the line $AD$ around $D$, as indicated in the diagram. As the angles at $A$ and $B$ increase, $C$ will be pushed further and further away from $D$.
If the obtuse angle $ADB$ is reduced to a right angle, then (by Pythagoras) $x$ will have been reduced to $15$. But in that case, the angles $DAB$ and $DBA$ will add up to $90^\circ$. So the angles $CAB$ and $CBA$ will add up to $180^\circ$. In other words, $AC$ will be parallel to $BC$ (or to put it another way $C$ will have gone off to infinity). In that case, $ABC$ will no longer be a triangle.
The conclusion from that is that $x$ cannot be reduced to $15$. So the smallest integer value that it can take must be $16$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
