What Is the Minimum Value of $f$ with Given Conditions?
In summary, the minimum value of a function is the smallest possible output value within a given domain. It can be found by setting the derivative of the function equal to 0 or using graphical methods. Finding the minimum value is important in scientific research as it helps identify optimal solutions and provides insights into variable relationships. A function can have multiple minimum values if it has multiple local minima, each representing a different optimal solution. To determine if a minimum value is global or local, the behavior of the function and its derivative can be examined at different points.
Albert1
1,221
find minimum value of $f$
given :
$(1)a,b,c,x,y\in R^+$
$(2)x+y=c$
$(3)f=\sqrt {a^2+x^2}+\sqrt {b^2+y^2}$
find :$min (f)$
Mathematics news on Phys.org
My solution:
I use raw calculus (Lagrange optimzation) and I would be happy to see other approaches:
\[f(x,y) = \sqrt{a^2+x^2}+\sqrt{b^2+y^2}\]
The constraint: $g(x,y) = x+y -c = 0$
Solving for $x (>0)$:
\[\frac{\partial f}{\partial x}=-\lambda \frac{\partial g}{\partial x} = -\lambda \: \: \: \wedge \: \: \: \frac{\partial f}{\partial y}=-\lambda \frac{\partial g}{\partial y} = -\lambda\]
\[ \Rightarrow \frac{x}{\sqrt{a^2+x^2}} = \frac{y}{\sqrt{b^2+y^2}}=\frac{c-x}{\sqrt{b^2+(c-x)^2}}\]
\[ \Rightarrow x^2(b^2+(c-x)^2)=(c-x)^2(a^2+x^2)\]
\[ \Rightarrow (b^2-a^2)x^2+2a^2cx-a^2c^2=0\]
\[ \Rightarrow x = \frac{ac}{a+b} \Rightarrow y = c-x = \frac{bc}{a+b}\]
- and the minimum value of f is: $f_{min} = \sqrt{(a+b)^2+c^2}$.
given :
$(2)x+y=c$
$(3)f=\sqrt {a^2+x^2}+\sqrt {b^2+y^2}---(1)$
find :$min (f)$
using geometry
consturct $\triangle ACD,\angle A=90^o, \overline {AC}=a+b=\overline {AB}+\overline {BC}$
$\overline {DA}=c=\overline {DQ}+\overline {QA}=x+y$
point $P$ is an inner point of $\triangle ACD,\overline {PQ}=a=\overline {AB},$ and $\overline {PQ}\perp \overline{AD}$
$\overline {PB}=y=\overline {AQ},$ and $\overline {PB}\perp \overline{AC}$
we have $(1):f=\overline {CP}+\overline {PD}\geq\overline {CD}=\sqrt{(a+b)^2+c^2}$
equality holds when point $P $ locates on $\overline {CD}$
FAQ: What Is the Minimum Value of $f$ with Given Conditions?
What is the definition of minimum value in a scientific context?
The minimum value of a function, denoted as f(min), is the smallest possible output value of the function within a given domain.
How can I find the minimum value of a function?
To find the minimum value of a function, you can set its derivative equal to 0 and solve for the input variable, or use graphical methods such as a graphing calculator or software.
Why is finding the minimum value important in scientific research?
Finding the minimum value of a function is important because it helps identify the most optimal or efficient solution to a problem, and can provide insights into the behavior and relationships of variables in a system.
Can a function have more than one minimum value?
Yes, a function can have multiple minimum values if it has multiple local minima. In this case, each minimum value represents a different optimal solution.
How can I determine if a minimum value is a global or local minimum?
A global minimum is the absolute lowest value of a function within its entire domain, while a local minimum is the lowest value within a specific interval. To determine if a minimum value is global or local, you can examine the behavior of the function and its derivative at different points.
