What is the molar mass of the unknown?
  • Thread starter huybinhs
  • Tags
    Mass
In summary: Is it clear now?In summary, to find the molar mass of an unknown substance, a 1.40 g sample is dissolved in 8.10 g of lauric acid, causing a depression of 1.23 oC in freezing point. Using the equation Delta T = Kf * m, we can solve for m and then use mole solute = m * mass of solvent to find the number of moles of the unknown substance. Finally, dividing the mass of the sample by the number of moles gives us the molar mass of the unknown, which is approximately 538.46 g/mol. It is important to not round down intermediate results and to include units in calculations for easier understanding.
huybinhs
230
A 1.40 g sample of an unknown is dissolved in 8.10 g of lauric acid. The freezing point is depressed 1.23 oC. What is the molar mass of the unknown?
Delta T = Kf * m
Delta T = Kf * m
=> m = 1.23 / 3.9 = 0.32
mole solute = 0.32 * 0.0081 = 0.0026 moles.
=> Molar mass = 1.40 / 0.0026 = 540 g/mol = final answer.
Am I doing correct? Please let me know!
Not bad. Two thngs that will make your solution better.
1. Don't round down intermediate results (check that it changes molar mass by about 8g).
2. Don't ignore units in your calculations, they are much easier to follow when it is obvious what is what of what.
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
Thanks so much for your response!
I have edited my answer to:
Delta T = Kf * m => m = 1.23 / 3.9 = 0.32 m
Molar mass of the unknown = 1.40 / 0.0026 = 538.46 g/mol .
Hope it better ;)
This time you overdid - you don't have enough information to give 5 significant digits in the answer :smile: But you see that rounding errors were responsible for 538 being 530.
Your approach is correct. To find the molar mass of the unknown, you first need to calculate the molality (m) of the solution using the given freezing point depression (ΔT) and the freezing point depression constant (Kf) for lauric acid. Then, you can use the equation m = moles of solute / mass of solvent to find the moles of solute (which is the unknown substance). Finally, divide the mass of the unknown substance by the number of moles to get the molar mass. Your final answer of 540 g/mol is correct. Good job!
Related to What is the molar mass of the unknown?
1. What is molar mass and why is it important?
Molar mass is the mass of a substance per mole. It is important because it is used to convert between the mass of a substance and the number of moles present, which is essential for many chemical calculations such as determining the amount of reactants needed in a reaction.
2. How is molar mass calculated?
Molar mass is calculated by adding the atomic masses of each element present in a molecule or compound. The atomic masses can be found on the periodic table of elements. The unit for molar mass is grams per mole (g/mol).
3. What is the difference between molecular mass and molar mass?
Molecular mass is the mass of a single molecule, while molar mass is the mass of one mole of a substance. Molecular mass is expressed in atomic mass units (amu) and molar mass is expressed in grams per mole (g/mol).
4. Why is the molar mass of an unknown substance important?
The molar mass of an unknown substance is important because it helps identify the substance. By comparing the molar mass of the unknown substance to known molar masses of elements and compounds, the identity of the substance can be determined.
5. How do you determine the molar mass of an unknown substance?
The molar mass of an unknown substance can be determined by using various experimental methods such as measuring the mass and volume of a given amount of the substance, and then using the ideal gas law to calculate the molar mass. It can also be determined by using techniques such as mass spectrometry or using a volumetric flask to measure the volume of a known concentration of the unknown substance.
9K
