What is the Most Efficient Fuel for Fusion Reactors: T-D, D-D, or D+He-3?
In summary, the question is whether a T-D or D-D fusion releases more energy. Although D-D fusion requires higher temperatures, DT fusion generates 17.6MeV while D+D fusion produces 4.03MeV (50% of the time) and 3.27MeV (50% of the time). However, tritium fuses quickly with deuterons, resulting in a larger cross section and producing 17.6MeV. Additionally, helium-3 also fuses easily with deuterons, generating 18.3MeV. Therefore, if a reactor fuses helium-3 along with deuterons, the total energy released would be 21.6MeV. However,
Basil Currie
Hi,
Does a T-D or a D-D fusion release more energy? Even if D-D needs higher temperatures, would it produce more energy in a fusion reactor?
In one way the deuterium tritium fusion generates 17.6MeV
D+T=2He4+n +17.6MeV
In the other way the D+D fusion is more complex:
D+D->T+p +4.03MeV (a 50% of the reactions)
D+D->He3+n +3.27MeV (a 50% of the reactions)
But tritium fuses very quickly with deuterons as cross section is much larger than D+D fusion and D+T generates 17.6MeV as said before
Also happens with the Helium-3 that fuses again more easily with deuterons giving 18.3MeV, so if the reactor fuses also helium-3 at the end you should have:
D+D+D->He4+n+p+ (4.03+17.6)*50%
D+D+D->n+p+He4+ (3.27+18.3)*50%
So:
D+D+D->He+n+p+21.6MeV
So D+D =2/3*21.6MeV=14.4MeV that is less than 17.6MeV.
But that is not the exact account as long as Tritium does not exists so it is generated using the generated neutron again lithium target to generate tritium releasing more energy that I did not took in account
Likes Dale
D+He-3 needs even higher temperatures for a relevant cross section than D+D.
If you don't need tritium as fuel you can use the neutrons for some exothermic reactions - even fission has been proposed (fusion-fission hybrid).
Related to What is the Most Efficient Fuel for Fusion Reactors: T-D, D-D, or D+He-3?
1. What is fusion of hydrogen isotopes?
Fusion of hydrogen isotopes is a nuclear reaction in which two or more hydrogen atoms combine to form a heavier element, releasing a large amount of energy in the process. This is the same process that powers the sun and other stars.
2. How is fusion of hydrogen isotopes achieved?
Fusion of hydrogen isotopes requires extremely high temperatures and pressures. This can be achieved through techniques such as magnetic confinement or laser fusion, which use powerful magnetic fields or intense laser beams to compress and heat the hydrogen isotopes.
3. What are the benefits of fusion of hydrogen isotopes?
Fusion of hydrogen isotopes has the potential to provide a nearly limitless source of clean energy. It produces no greenhouse gases or long-lived radioactive waste, and the fuel (hydrogen) is abundant in seawater.
4. What are the challenges of achieving fusion of hydrogen isotopes?
The main challenge in achieving fusion of hydrogen isotopes is controlling and sustaining the extremely high temperatures and pressures necessary for the reaction to occur. Additionally, the technology and infrastructure needed to harness fusion energy is still in the early stages of development.
5. When will fusion of hydrogen isotopes be a viable energy source?
There is no definitive timeline for when fusion of hydrogen isotopes will become a viable energy source. While significant progress has been made in recent years, there are still many technical challenges that need to be overcome before it can be harnessed for practical use.
