MHB What is the multiplier for finding the area of triangle ADG?
To find the area of triangle ADG, the area formula A = (bh)/2 is applied, where b represents the base and h the height. The area of triangle CDE is expressed in terms of segments AG and DG, leading to the equation (1/3 AG * 1/3 DG)/2 = 42. To determine the area of triangle ADG, a multiplier must be identified for both sides of the equation. The discussion highlights the challenge of interpreting a small image related to the problem. Ultimately, the focus is on deriving the correct multiplier for calculating the area of triangle ADG.
alextrainer
Not sure how to use a single area and line segments that are same to calculate the areas and line segments for the areas.
Mathematics news on Phys.org
Using the formula for the area, $A$, of a triangle
$$A=\frac{bh}{2}$$
where $b$ is the base of the triangle and $h$ is the height of the triangle, can you state the area of triangle $CDE$ in terms of $AG$ and $DG$?
(3)42 = 84/2 so b times h equals 84
$$\frac{\frac13AG\cdot\frac13DG}{2}=42$$
Now, what number can we multiply both sides of the above equation by to find $\triangle{ADG}$?
Greg, I'm glad you can read that tiny sideways image, because I sure can't. (Bandit)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
