Geoffrey F. Miller
- 14
What is the name of the device used to measure ohms? ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The device used to measure ohms is called an ohmmeter. It is also sometimes referred to as a multimeter or a volt-ohm meter (VOM).
An ohmmeter measures the electrical resistance of a circuit or component by sending a small amount of current through it and measuring the voltage drop. The resistance is then calculated using Ohm's Law (R=V/I).
Yes, an ohmmeter can also measure voltage and current. It typically has multiple settings for different units of measurement, such as volts, ohms, and amps.
No, an ohmmeter measures resistance while a continuity tester checks for breaks in a circuit. However, some ohmmeters have a continuity testing function.
Yes, there are analog and digital ohmmeters. Analog ohmmeters use a needle to display the measurement on a scale, while digital ohmmeters have a digital display. There are also handheld and benchtop ohmmeters, with different features and capabilities.
