What Is the Natural Angular Frequency of a Cantilevered Body?
In summary, a body A weighing 22N is positioned on the end of a slender horizontal cantilever fixed at one end. A force (vertically downwards) on A causes a deflection of 12.5mm. The natural angular frequency of the body A is approximately 24 rad/s based on the given choices.
zorro
1,384
A body A weighing 22N is positioned on the end of a slender horizontal cantilever fixed at one end (mass of the plank is negligible). A force (vertically downwards) on A causes a deflection of 12.5mm. The natural angular frequency in rad/s of the body A is (nearly) ?
1)2
2)6
3)24
4)1.2
F=kx
k=22/0.0125
w=(k/m)1/2=28rad/s, not in the choices. Did I make any mistake?
Usually your method would work for a spring, but I think a cantilever is a bit different.
If you look in this thread, you will find a different formula
https://www.physicsforums.com/showthread.php?t=275927
You can get the value for EI/L3 using
deflection = PL3/3EI where P = load and L = length of beam
What are W,E and I?
Abdul Quadeer said:
What are W,E and I?
Actually now that I see that formula, it is essentially the same as what you did.
The most I can say is 24 rad/s would be the best answer given that you need to choose from those 4.
Your calculation for the spring constant (k) is correct, but you have made a mistake in calculating the angular frequency (w). The correct formula for the natural angular frequency of a cantilever is given by w = (k/m)^0.5, where m is the mass of the body (not the plank). Since the mass of the body A is not given, we cannot calculate the exact angular frequency. However, we can use the given information to approximate the answer.
Assuming the mass of the body A is negligible compared to the mass of the plank, we can use the given weight of 22N to estimate the mass of the body as m = F/g = 22/9.8 = 2.24kg. Plugging this into the formula, we get w = (k/m)^0.5 = (22/0.0125/2.24)^0.5 = 11.1 rad/s. This is closest to option 2) 6 rad/s, which would be the correct answer for this approximation. So, the approximate natural angular frequency of the body A in this scenario is 6 rad/s.
FAQ: What Is the Natural Angular Frequency of a Cantilevered Body?
What is the definition of cantilever angular frequency?
Cantilever angular frequency refers to the rate at which a cantilever, a structure that is supported at only one end, oscillates or vibrates back and forth.
How is cantilever angular frequency calculated?
Cantilever angular frequency can be calculated using the formula ω = √(k/m), where ω represents the angular frequency, k represents the spring constant of the cantilever, and m represents the mass of the cantilever.
What factors can affect cantilever angular frequency?
The main factors that can affect cantilever angular frequency are the length, mass, and stiffness of the cantilever. Other factors such as temperature, material properties, and external forces can also have an impact.
Why is cantilever angular frequency important in science?
Cantilever angular frequency is important in science as it is used to measure the properties of materials and analyze their behavior under different conditions. It is also used in various technologies such as microelectromechanical systems (MEMS) and atomic force microscopy (AFM).
Can cantilever angular frequency be changed or manipulated?
Yes, cantilever angular frequency can be changed or manipulated by altering the length, mass, or stiffness of the cantilever, or by applying external forces such as vibrations or magnetic fields.
