What is the nature of the origin of reciprocal space, please?
In summary: The origin of reciprocal space is determined by diffraction. The diffraction holds the same direction as the incident light with diffraction vector being zero. So, the origin can be easily located as the head of an incident wave vector in Ewald’s sphere.
wangasu
33
Hi, all
I got a question about the origin of reciprocal space..what is the physical nature of the special point? Does that originate from diffraction? or Is that a diffraction points? We know that a 'normal' reciprocal point designates a group of parallel plane. How about the origin of reciprocal space?
In a powder diffraction, we observed only ONE origin of reciprocal space from a huge number of small single crystals. By contrast, the other points which correspond to a CERTAIN plane form a sphere surrunding the origin of reciprocal space..Why does all the origin of reciprocal space for all the single crystal in the power sample come into one point? What factors determine the location of the special point? Is that associated with the direction of the incident beam? Thank you.
Your concepts seem a bit convoluted. The reciprocal space is a mathematical construct. There is a connection between its origin and a plane wave of zero frequency (i.e. a constant) In diffraction the incident light can only change its k vector by the value of a point on the reciprocal lattice. If that is the origin, the light's direction doesn't change and it goes straight through. The reciprocal lattice is a set of points from the reciprocal space.
Thanks Ox..It sounds that it is true that the origin of reciprocal space comes from diffraction, and the diffraction holds the same direction as the incident light with diffraction vector being zero. So, the origin can be easily located as the head of an incident wave vector in Ewald’s sphere. Here is one more question. In practice, the origin of electron diffraction patterns is always a bright spot, can we say it concerns both transmission and diffraction? Thanks.
Hi,
reciprocal lattice are often seen in transmission electron microscopy. Just look at the web for the two modes of operation (transmission and diffraction mode)..In fact both are same (both images you get after the electron passes the crystal sample)..but one changes the plane to view whether the DP or Image. In a diffraction pattern (may be you know it- bright dots) the distance between point are given in inverse units (like 1/cm, or 1/nm, etc)...But if you take a image..scale will be like 1 cm=1 nm.
Little bit helps you.
Right..an electron diffraction image of TEM is the projection of the crossection between the reciprocal lattice points and Ewald's sphere. it seems that the origin of the electron diffraction image definitely explains both transmission AND diffraction, NOT just transmission..does it make sense?
But don't forget..in TEM for getting diffraction or image, the electron is transmitted through sample. THatz why transmission electron microscopy.
Related to What is the nature of the origin of reciprocal space, please?
1. What is reciprocal space?
Reciprocal space is a mathematical representation of the structure of a crystal in three-dimensional space. It is often used in crystallography to analyze the diffraction patterns produced by a crystal.
2. What is the relationship between real space and reciprocal space?
Real space and reciprocal space are closely related, as they are both representations of the same crystal structure. In real space, the positions of atoms are represented in Cartesian coordinates, while in reciprocal space, the positions of reflections are represented in terms of their corresponding wavelengths and angles.
3. How is reciprocal space related to diffraction patterns?
Reciprocal space is used to analyze diffraction patterns because it provides a way to visualize the different wavelengths and angles of the diffracted rays. This allows for the determination of the crystal's internal structure and the arrangement of atoms within it.
4. What is the significance of reciprocal space in crystallography?
Reciprocal space is essential in crystallography because it allows for the determination of crystal structures and the arrangement of atoms within them. It also helps in the analysis of diffraction patterns and the identification of crystal symmetry.
5. How is reciprocal space calculated?
Reciprocal space is calculated using a mathematical technique called Fourier transformation. This involves converting the crystal's diffraction pattern (measured in terms of intensity and angle) into reciprocal space (measured in terms of wavelength and angle). The resulting reciprocal lattice is then used to determine the crystal's internal structure.
  • Atomic and Condensed Matter
